C320 shaking at idle and turns off - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-16-2010, 10:24 AM Thread Starter
Date registered: Jun 2010
I started having this problem with my 2002 C320 about 2 weeks ago. The car started shaking at idle. Then the shaking started happend while driving it. It felt like the car was going to die and I was not able to pick up any speed when stepping on the gas. About 2 days ago I was driving to work, check engine light came up and the car died. I restarted it and was able to drive back home, it died a few times in like a 2 mile drive. I left it alone and now that I wanted to take it to the shop the battery died. I put another battery but I start the car it shakes a bit and then turns off. Any help with this would be appreciated.
totisleon is offline
post #2 of 3 (permalink) Old 06-16-2010, 02:01 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Welcome to the forum.
First things first: please complete your BW Profile:
As to your immediate issue, shaking sounds like it is shutting down cylinders which is pretty serious. It could also be the Crank Position Sensor, a relatively inexpensive part that is simple to change.
If you've been ignoring maintenance this could get expensive, but the place I'd probably start is reading the codes. If you don't want to take it somewhere buy a cheap code reader (Amazon has one for $40) and get the codes, that will point you in the right direction.
Also, please note that you posted in the general forum. You're much more likely to get help on a specific issue by posting in the forum that is specific to your car, the W202. Scroll down and you'll see it in the sedan section.
Good luck.
Check Codes is offline
post #3 of 3 (permalink) Old 06-16-2010, 03:18 PM Thread Starter
Thanks for the reply. I will definitely post at the right place next time. The Crank Position Sensor was replaced last summer and I alway do the services on time. Im going to buy the code reader and go from there.
Thanks,
    Shaking at idle orlandotrader W163 M-Class 8 03-14-2011 03:57 PM
    SL engine 'shaking' at idle clipster R129 SL-Class 15 05-19-2009 12:16 AM
    Idle Shaking garrettsmith W123 E,CE,D,CD,TD,TE Class 4 11-13-2006 09:52 PM
    Shaking engine while idle jf23668532 General Mercedes-Benz 1 06-28-2005 05:03 PM
    shaking at idle while in "D" FIXED!!! snik W124 E,CE,D,TD Class 24 03-31-2005 06:59 PM
