PHANTOM PROBLEM - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 06-13-2010, 10:56 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Originally Posted by JoeVal View Post
Engine temp sensor?
Could explain high engine temperature but would not prevent the car from starting.
Diesel Benz is offline
post #12 of 18 (permalink) Old 06-13-2010, 11:07 PM
eric242340's Avatar
Quoted: 299 Post(s)
Two most common causes of this are the Crankshaft position sensor, which has been replaced to no avail and the fuel pump. The fuel pump will not put the CEL on and will not give fault codes.
ERIC.
eric242340 is online now
post #13 of 18 (permalink) Old 06-13-2010, 11:27 PM
Kajtek1's Avatar
Quoted: 1191 Post(s)
I heard the computer will kill the engine when it gets too hot as a self-protection.
Than fuel pump on MLs don't have good reliability records.
The famous electrical connections that burn inside the gas tank.
Pump failure is easy to troubleshoot by pushing the valve on top of fuel rail.
Kajtek1 is offline
post #14 of 18 (permalink) Old 06-20-2010, 01:44 PM Thread Starter
Date registered: Jun 2010
new battery
biddy is offline
post #15 of 18 (permalink) Old 06-20-2010, 01:46 PM Thread Starter
new battery installed, engine light is on
biddy is offline
post #16 of 18 (permalink) Old 06-20-2010, 03:43 PM
Kajtek1's Avatar
What engine light?
Is the car running fine now?
Kajtek1 is offline
post #17 of 18 (permalink) Old 06-21-2010, 03:52 PM
Date registered: Jan 2010
Vehicle: E 550 4 matic 2010
I traded my 1998 ML in after having the same issue that could not be corrected. I didn t trust it after that.
2010 E550 4matic, AMG Package
cerbomark is offline
post #18 of 18 (permalink) Old 07-08-2010, 06:06 PM
Date registered: Sep 2006
Vehicle: 1996 C220 150K
Did you ever diagnose your hot starting problem? I also have it. Same symptoms as you have. When car is hot after driving, or even after it just sits in the sun, when I turn the key the instrument panel lights up but there is no sound from under the hood. I hear the fuel pump though (in the back).
When the car cools down it starts normally.
Skip Savage is offline
    Phantom Shakes in2dwww W140 S-Class 43 03-24-2011 11:25 PM
    Phantom Voices ... Indiana Drew W220 S-Class 0 02-13-2010 01:07 PM
    I will drive a Phantom soon Natant Maybach 35 01-07-2008 04:03 PM
    Phantom noise GPS W210 E-Class 2 06-09-2007 05:49 PM
    Phantom Posts dahappybanana Off-Topic 5 06-25-2005 07:36 PM
