Does this sound like bad wires? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-11-2010, 04:52 PM Thread Starter
Date registered: Nov 2009
Vehicle: 2001 S55 AMG
So about 20k miles ago, I changed the spark plugs on my S55. I did not change the wires, they are original 137k miles right now.
Recently, I have noticed a bit of an interrupted idle, it's not a smooth surge like before, but a bit rough; and after coming to a stop after highway driving, it's more pronounced.
I am not sure if there is a loss of power across the band, but I suspect it's a little bit different..the roughness is just at idle pretty much, not when in higher rpms.
I ruled out a mass airflow sensor, as I was told the symptoms differ and I'd get a check engine light which I don't have, so are the spark plug wires the culprit here most likely?
crashtest is offline
post #2 of 3 (permalink) Old 06-12-2010, 03:51 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
without proper diagnosis no one can tell you if they are the cause or not. a short test is needed to check for any codes. also bad wires usually cause a rough idle at all times, and through actual values in das the corrupt cylinder can be detected.
Streetglower is offline
post #3 of 3 (permalink) Old 06-12-2010, 09:14 AM
eric242340's Avatar
Quoted: 283 Post(s)
Have your fuel injectors been cleaned and tested?
eric242340 is online now
    Is this the sound of a water pump going bad? Arcticfox General Mercedes-Benz 7 10-14-2010 04:55 AM
    What are the symptoms of ignition wires going bad? MaxMatt W124 E,CE,D,TD Class 20 06-05-2010 09:52 AM
    idle studdering, almost shutting off, bad acceleration, spark plug wires ventura300se W140 S-Class 6 07-13-2009 09:54 PM
    Did SRS seat pad fix, wires intact, bad sensor? Little W210 E-Class 6 06-04-2008 03:29 PM
    420 lo spd missing cause=bad plug wires dan1 W126 S,SE,SEC,SEL,SD,SDL Class 4 07-19-2006 04:44 AM
