Idle control unit - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-09-2010, 11:04 PM Thread Starter
Date registered: Jun 2010
Idle control unit
hey, my 300se has a bit of a unstable idle so im assuming its the idle control unit. does anyone know where it is located in the car?
cheers for any help.
patrickgledhill is offline
post #2 of 8 (permalink) Old 06-10-2010, 05:06 AM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 177 Post(s)
unstable idle
Bad assumption. Look for a vacuum leak first. Most common and easiest/cheapest to fix.
rocky raccoon is offline
post #3 of 8 (permalink) Old 06-10-2010, 06:00 AM
scottx's Avatar
Date registered: Apr 2010
Vehicle: 85 190e/8v & 89 420 SEL
Send a message via AIM to scottx
I totally agree. Mine was doing the same thing and we cleaned the ICU and fixed a few vacuum leak's. It idles much smoother now.
Professional Mobile Electronics Installer & Fabricator [R]
Champagne Dream - w201.024 - http://www.ChampagneDream.org/
scottx is offline
post #4 of 8 (permalink) Old 06-10-2010, 06:05 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Purpose of idle control unit is to provide extra air when engine is running "on choke," i.e. after a cold start when idle mixture is richer than normal.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #5 of 8 (permalink) Old 06-10-2010, 07:11 AM
Date registered: Jul 2004
Quoted: 312 Post(s)
Which 300SE? A 300SE can be from the 60s (112), 80s/to 91 (126) or early 90s (140). Depending on which model it is it may not even have an idle control valve.
deanyel is offline
post #6 of 8 (permalink) Old 06-14-2010, 03:10 PM Thread Starter
it is the w126 1987 300se. i will have a look at the vacuum hoses tonight. it there a easy way to check the hoses?
cheers
post #7 of 8 (permalink) Old 06-14-2010, 08:25 PM
scottx's Avatar
How to check for vacuum leak's.
cheers
Just look at each hose separate and make sure they don't have any cut's/hole's etc. Look for hose's that have come off and are no longer connected and then.. reconnect them.
You can always use the starter fluid trick by spraying around hose area's and if the idle raises, then it's sucking the fluid in somewhere and burning it. That would be a leak. That's also a good way to check if an intake manifold gasket is leaking.
scottx is offline
post #8 of 8 (permalink) Old 06-14-2010, 09:28 PM Thread Starter
checked all hoses ect. but it is still very unstable. the most it will raise to is 1500 and the least is 500. also when you accelerate hard in park or neutral it will rev up have a slight pause and rev all the way. could it be a fuel filter or pump? sometimes it takes ages to start as if no fuel is reaching the injectors.
    Idle Control Unit Jukka L. W126 S,SE,SEC,SEL,SD,SDL Class 2 05-13-2006 07:10 AM
    ROUGH IDLE, IDLE CONTROL UNIT LOCATION, TIMING & RPM verdejor W126 S,SE,SEC,SEL,SD,SDL Class 16 02-15-2006 10:52 AM
    ROUGH IDLE, IDLE CONTROL UNIT LOCATION, TIMING & RPM verdejor General Mercedes-Benz 5 01-22-2006 08:41 PM
    idle control unit Guest (MBNZ) R/C107 SL/SLC Class 3 07-25-2002 01:55 PM
    idle control valve vs idle control unit Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 04-15-2002 12:38 PM
