Misfire Codes - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-09-2010, 02:00 PM Thread Starter
Date registered: Jun 2010
Misfire Codes
Earlier someone posted the cylinder numbers for a CL600 MB. Lokking into the engine compartment from the front of the car RT bank 1,2,3,4,5,6 and LT bank 7,8,9,10,11,12? Is this correct?
I was getting Fault codes PO303 and PO308. I replaced the those plugs deleted the Fault codes and got the same Fault Code after taking the car on a test drive. I again removed the plugs and they apear to have not fired. I then exchanged what I think is cyclinder 2 coil with cylinder 3 coil to see if maybe the coil was bad. My thought was I should get Fault PO302 and Fault PO308 if the coils were bad? What I got was a Fault Code PO309?
Can someone confirm the cylinder numbers please?
Thanks,
wtlnsteve is offline
post #2 of 3 (permalink) Old 06-13-2010, 08:11 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 210,xxx Miles
Quoted: 5 Post(s)
leapyfish is offline
post #3 of 3 (permalink) Old 06-14-2010, 04:31 AM Thread Starter
Can't find answer to anything I've requested in the vehicle area?
    Misfire and codes tenknots W140 S-Class 1 02-16-2009 08:44 AM
    Misfire, codes P030x brent1777 W203 C-Class 12 02-08-2008 10:28 AM
    Misfire Codes rmt6668 W202 C-Class 0 01-19-2008 03:44 PM
    After getting my codes checked out, they say "Misfire Codes" for my s500 gahmed General Mercedes-Benz 10 07-17-2007 05:06 PM
    Help with engine misfire codes johnny63ml320 W163 M-Class 15 11-14-2006 05:52 PM
