Vaccume Hose loose Whats the danger? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-09-2010, 11:36 AM Thread Starter
benzo190e's Avatar
Date registered: Jun 2010
Vehicle: 93 Mercedes Benz 190E 2.6
Unhappy Vaccume Hose loose Whats the danger?
I was driving one day last week and I noticed out of the blue that when I stopped at a light my benz began to shake a little at just sitting still. When i got home I noticed one of my vaccume lines was hanging off. problem is no one knows where it goes. Please help. Also I have a check engine light that jumped on. There goes my smooth idle. does anyone know or have experienced this problem? Oh yeah I also noticed this tube comming from the firewall I know the guy that sold me the benz Un hooked the heater core cause it was leaking I assume this is the othe end?. The vaccume hose is pictured on the left It's the third one to the right the other end I put a screw in till I find out where it goes.
ID:	312928   Click image for larger version
benzo190e is offline
post #2 of 2 (permalink) Old 06-10-2010, 09:58 AM
Kajtek1's Avatar
Quoted: 1167 Post(s)
The vacuum controls on this cars play the same role what computers on newer do.
Disconnected tubing disables a sensor or a control and that is what affects the engine.
Some manual do have vacuum system diagrams. Sometimes there is a label under the hood. I have similar dilemma where PO bypassed a sensor hanging on the firewall. Can't find what this is for, but the engine runs fine, so I am not worry. Assuming the bypassed sensor is bad I hesitate to reconnect it, especially not knowing how it goes.
Post your question in the forum for you car model for better exposure?
Kajtek1 is offline
    Help identify a loose hose! Episode7 R170 SLK-Class 3 11-06-2009 10:40 PM
    Loose Vacuum Hose Keepontrucking R129 SL-Class 5 06-11-2009 12:10 PM
    Loose Hose isarescu R170 SLK-Class 5 05-26-2008 06:54 PM
    Question on Main Vaccume Line/Hose Winston W123 E,CE,D,CD,TD,TE Class 4 02-13-2007 12:39 AM
    Loose hose under the hood SpeedDemon R129 SL-Class 0 11-09-2006 08:47 PM
