New car on the block - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-09-2010, 02:48 AM Thread Starter
jl772009's Avatar
Date registered: May 2010
Vehicle: 1987 Mercedes Benz 300E W124
Hi Everyone,
I am Javan and I own a 1987 300E. The car currently has 237k on it and it drives like no other car I've driven before. I bought it for $1200 from a guy who had it gifted to him. Needless to say he didn't maintain it as he should have. He had all the maintenance records of what was done before he got a hold of it. He did do some work but I knew he didn't know what he was doing when he was taking the car to Jiffy Lube. So far I have replaced the front suspension except the struts and I replaced the rear suspension. Replaced fuel injectors,EHA valve, OVP, brakes, plugs and wires,fuel filter,tires,engine mounts,flex disc,transmission filter gasket, and water pump. Getting ready to replace radiator and transmission lines they are leaking.
I am wanting to change my valve cover gasket. Is that also known as the timing chain cover? I am seeing leaks all around it and the gasket is hard like plastic. By the way I am in Seattle,WA.
jl772009 is offline
post #2 of 3 (permalink) Old 06-13-2010, 10:52 AM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 210,xxx Miles
Quoted: 6 Post(s)
leapyfish is offline
post #3 of 3 (permalink) Old 06-19-2010, 02:36 PM
Date registered: Jun 2010
It is the cam/chain cover and with about 225-240K on the engine I would bet the chain has not been replaced. It is due. And DO NOT lose the chain keeper inside the engine. You will cry if you do! Any gaskets, especially, around the head or thermo stats (there are several under the manifolds) that get hard are due for replacements or overdue. Use a german brand not the chinese.
Tom Hardy is offline
Won't start, headrest up, drove over concrete block, car bounced. Pancho C208/A208 CLK-Class 8 07-07-2009 08:51 AM
What are the differences between the 430 block and e55 K block nastyclk C208/A208 CLK-Class 0 12-22-2008 01:31 PM
Long Block vs. Short Block, What's the Difference? kabul General Mercedes-Benz 3 12-30-2005 05:11 PM
New Car On The Block Tahloube W126 S,SE,SEC,SEL,SD,SDL Class 5 08-28-2005 05:20 PM
My car starts fine but cant start it again if i have only been around the block? danol W124 E,CE,D,TD Class 3 05-06-2003 05:03 PM
