Aircon radiator fan problem - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 06-08-2010, 03:28 AM Thread Starter
Date registered: Jun 2010
Hello
I have a 1997 C-class 250 turbodiesel on which only one of the 2 aircon radiator fans ever runs... is this normal? If its that the fan is broken, does anyone know of a link to a "how-to" sort of page showing how to get the things off and how to acces the electrical input for testing?
Thanks!
crowcrow is offline
post #2 of 10 (permalink) Old 06-09-2010, 02:15 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
No, that is not normal. I'm surprised the A/C has been cooling very well and/or the car running too hot. Sounds like one of the fan motors is seized. Try spinning it by hand. If it doesn't move then it needs to be replaced.
mr.xpowerseller is offline
post #3 of 10 (permalink) Old 06-09-2010, 02:37 PM
Musikmann's Avatar
Quoted: 6 Post(s)
The 1998 E-Class (not a diesel) I used to own had 2 fans but only one was motored and the other was driven by a belt connected to the fan with the motor. So in other words the belt might be missing.
Musikmann is offline
post #4 of 10 (permalink) Old 06-09-2010, 02:42 PM
~BANNED~
I think if his fan belt was snapped, the car would be melting if he was continuing to drive it. I think he is talking about the aux condenser cooling fans.
post #5 of 10 (permalink) Old 06-09-2010, 02:47 PM
Musikmann's Avatar
Quoted: 6 Post(s)
You might be correct but "2 aircon radiator fans" is a bit ambiguous. Maybe the OP will clarify? My car was not overheating when that belt was discovered to be missing but I don't remember what time of year that was.
post #6 of 10 (permalink) Old 06-09-2010, 02:54 PM
~BANNED~
Your fan belt had snapped and you didn't notice it and kept driving the car??? I guess it would be possible at the North Pole or if you had a very small econobox 4 cylinder, but otherwise I don't believe it. The belt normally explodes and wrecks at least one other thing in the engine bay, then you car starts overheating and/or melting if you keep driving.
post #7 of 10 (permalink) Old 06-09-2010, 03:04 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Not the serpentine belt, the tiny fan belt connecting the 2 fans that I described. They said it is about the thickness of a rubber band.
post #8 of 10 (permalink) Old 06-10-2010, 12:48 AM Thread Starter
Thanks for the replies. In fact the fan turns very easily by hand, and it has to be said the aircon isn't wonderfully effective... it does run a bit hot in the summer, but nowhere near the red on the temperature guage. I think Musikmann's idea about a small belt linking the two fans is a real possibility, but I can't see any obvious place it should be fitted - has anyone else seen this system before, is it the usual thing on this model? Just to clarify, I'm not talking about the big fan mounted on the inside of the main radiator (which is turned by the serpentine belt) but the two small fans mounted right on the outside front of the vehicle which are presumably electrically activated whenever the A/C is turned on.
crowcrow is offline
post #9 of 10 (permalink) Old 06-10-2010, 07:38 AM
Kajtek1's Avatar
Quoted: 1223 Post(s)
Take a closer look at both fans. Usually one has big center with motor in it and the other just smaller center with pulley in it. The belt is not visible behind the grille. You have to remove the covers to see where it is missing. Shop around since those small belts cost well over $20.
Kajtek1 is offline
post #10 of 10 (permalink) Old 06-12-2010, 07:19 AM Thread Starter
Hmm, the fans look absolutely identical. I guess I'll just have to take them off and have a thorough look!
crowcrow is offline
    Radiator fan problem BarryNH W204 C-Class 14 01-08-2010 08:52 AM
    Electric radiator fan problem NYML55AMG W163 M-Class 3 12-21-2008 11:37 AM
    Electric radiator fan problem NYML55AMG General Mercedes-Benz 0 11-29-2008 07:51 AM
    Head gasket leveled, New Radiator, new Thermostat, New fan clutch, both Auxiliary fan Workersvillage W124 E,CE,D,TD Class 11 08-10-2008 10:32 PM
    '91 500SL radiator & aircon condenser upgrade Chicky R129 SL-Class 8 05-12-2007 07:32 AM
