Splicing wiring harnesses - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-05-2010, 06:37 PM Thread Starter
Date registered: Jun 2007
Vehicle: 1995 SL 500 2005 SL500
Quoted: 5 Post(s)
Post Splicing wiring harnesses
see PDF
Lee Wireless is offline
post #2 of 2 (permalink) Old 06-07-2010, 04:43 AM
Date registered: Jun 2010
If you do splice the wires, you will do better if you solder the wire ends and use a shrink cover, which is a piece you slip over the soldered area and heat to shrink it to the wire. If you use wire connectors they can vibrate and the wire will break at the connection, and sometimes they get a corrosion inside them because most are a small aluminum sleeve that you crimp and they break also.
michel smith is offline
    Wiring harnesses different? Zachmac General Mercedes-Benz 0 02-18-2009 04:58 PM
    How many wiring harnesses on a 95 E300D? drgreenthumb W124 E,CE,D,TD Class 1 09-22-2008 08:38 AM
    engine wiring harnesses matteus W201 190-Class 21 02-03-2006 03:24 PM
    Wiring harnesses on w140 in general. mbdiesel W140 S-Class 5 06-10-2005 07:17 AM
    1995 SL wiring harnesses SL3204me R129 SL-Class 8 01-08-2005 04:59 PM
