1988 560 sec - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 06-04-2010, 05:01 PM Thread Starter
Date registered: Jun 2010
Post 1988 560 sec
I recently purchased a 1988 560 sec, she's a beauty, never owned one before and really like her! It has 162,000 miles and the problem I am having is that the rear bounces up and down quite a bit like the rear shocks are shot, any imput on what may be the problem with it. Thanks for any info
emscheif is offline
post #2 of 10 (permalink) Old 06-04-2010, 05:16 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
When was the suspension last overhauled?
mr.xpowerseller is offline
post #3 of 10 (permalink) Old 06-04-2010, 10:59 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 667 Post(s)
You may need new rear suspension accumulators -- common enough....
GeeS is offline
post #4 of 10 (permalink) Old 06-05-2010, 06:26 AM Thread Starter
Thanksfor all the replies, Don't know if the suspension has ever been overhauled, suspension accumulators? This all sounds (french to me) Doesn't sound like changing a pair of shocks, Thanks to all
emscheif is offline
post #5 of 10 (permalink) Old 06-05-2010, 10:01 AM
Musikmann's Avatar
Quoted: 6 Post(s)
GermanStar ought to know.
Musikmann is offline
post #6 of 10 (permalink) Old 06-05-2010, 10:39 AM
~BANNED~
Have you searched the W126/C126 section for answers?
post #7 of 10 (permalink) Old 06-05-2010, 10:42 AM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 667 Post(s)
You'll find 'em here: Mercedes W126 Steering and Suspension Parts
First item on the page. No guarantee that's the issue of course, but it does fit the symptom and it's quite common. Your car is not equipped with standard shocks, it has load-levelers. If it were equipped with standard shocks, I would agree with your initial assessment.
GeeS is offline
post #8 of 10 (permalink) Old 06-05-2010, 10:50 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
"Accumulators refers to the fact this car has air suspension and does not have conventional shock absorbers.
Where you might normally find shock absorbers are instead load levelers. They are seldom replaced unless they are leaking, and then they are always replaced singly, i.e. just replace the one that's leaking.
The "shock absorber" function is performed by accumulators, which look like round balls and are probably hidden somewhere where you can't see them without removing body panels in the trunk.
Accumulators are normally replaced in pairs and are maybe $100-200 each, while the load levelers are more like $800-900 each. It's MUCH more likely the problem is the accumulators (assuming the system has no leaks and the hydraulic pump functions correctly) and you should ask for lots of "proof" if the tech wants to replace one or more load levelers.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #9 of 10 (permalink) Old 06-05-2010, 06:31 PM Thread Starter
Thanks to all for all the helpful responses I'll have to do some investigation and see if I can locate the Accumulators, Not sure what i'll do after I find them! Again THANKS to all who responded
emscheif is offline
post #10 of 10 (permalink) Old 02-11-2011, 01:48 PM
Date registered: Sep 2010
Bouncing ...
I have the same issue, diagnosed as the accumulators (as previously mentioned). Also, as previously stated, cost averages between $400 - $500.00.
Genes88SEC is offline
    1988 560 sec battery replacement henylo W126 S,SE,SEC,SEL,SD,SDL Class 9 07-01-2009 09:43 AM
    1988 560 SEC srf25 W126 S,SE,SEC,SEL,SD,SDL Class 1 12-18-2008 05:08 PM
    1988 560 SEC AMG MorrisTigerson69 W126 S,SE,SEC,SEL,SD,SDL Class 3 03-25-2006 01:38 PM
    CO 1988 560 SEC Minkoff W126 S,SE,SEC,SEL,SD,SDL Class 0 02-15-2006 12:43 PM
    Replacing yellow headlights in my 1988 560 sec caseydellas W126 S,SE,SEC,SEL,SD,SDL Class 1 08-23-2003 07:07 PM
