thermostat sensor location??? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-04-2010, 11:55 AM Thread Starter
Date registered: Aug 2009
Question thermostat sensor location???
I have a 97 benz e320. I replaced the thermostat but now I need to replace the thermostat sensor. Does anyone know where it is located?
rydinfly is offline
post #2 of 2 (permalink) Old 06-05-2010, 03:11 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 343 Post(s)
You would stand more chance of a response if you had posted in the W210 forum, where owners of similar cars gather.
No idea myself - but it is called B11/4 on the drawing, and called the coolant temperature sensor. I would expect it to be located quite close to the thermostat you have just changed. Look about for a device with an electrical connector that is also installed into the hot coolant path.
keyhole is online now
    Hood opening and location of the CPS Sensor and Pre-Cat O2 sensor Check Codes W210 E-Class 55 06-22-2015 09:47 AM
    Thermostat, temp sensor and coolant level sensor change martinriff V-Class 4 05-29-2010 04:52 AM
    vito thermostat location pmruk V-Class 0 05-11-2009 02:03 PM
    Thermostat location 05 C230 kompressor tnc230kompressor W203 C-Class 0 01-29-2008 10:44 AM
    95 E200. Oil sender sensor location, brake pad sensor location, engine code? cubicincubi W124 E,CE,D,TD Class 2 01-04-2006 08:07 AM
