Change rotors when changing pads? - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 06-01-2010, 10:12 AM Thread Starter
Date registered: Jun 2010
Exclamation Change rotors when changing pads?
I own a C-280 sport, this is my first benz and i'm lovin it!
QUESTION..
I want to get the pads changed as they are starting to wear down. I called my local foreign car shop and they only change the pads with rotos, NOT pads only.
I only know american cars, but i have always only changed the rotors if there is obvious wear on them ie: (discoloration or warping).
Do i have to get the rotors changed as well?
If so, why is that?
juka_benz is offline
post #2 of 13 (permalink) Old 06-01-2010, 10:27 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
It's fairly normal these days, but there are published figures regarding measuring the remaining thickness of the rotors.
There are two numbers.
1. Never go below this number
2. Replace anyway when changing pads because rotor will be worn out before the pads.
You can reach through your wheel and feel/observe whether there's a "lip" on the outside edge of the rotor that indicates amount of missing metal.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 13 (permalink) Old 06-01-2010, 11:08 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 375 Post(s)
I am surprised to read both of those statements...
a) I understand that it's very common to replace the pads only. I have myself.
b) I have never replaced a rotor. (many cars, many years) WIS suggests disc replacement when thickness is reduced by 2.0 - 2.5mm from the original. As you said, it would be obvious to the touch.
keyhole is online now
post #4 of 13 (permalink) Old 06-01-2010, 11:46 AM
Date registered: Dec 2008
Vehicle: w204 (C350ELE)
It is perhaps a bit more complex than this, to include warping, wobbling, run-out, different disc thicknesses and materials... but you are right. Rotor wear is different than pad wear and the two should be evaluated separately and then revamped so they are able to work properly together till the next scheduled service.
A car would show appreciation for preventive maintenance by never leaving his owner stranded.
Defensive Driving is never having to say you're sorry: a true love story between man and machine.
JoeVal is offline
post #5 of 13 (permalink) Old 06-01-2010, 02:03 PM
Quoted: 2 Post(s)
Lots of folks are still living in the 1990s (or earlier).
TODAY's cars feature light brake rotors as an attempt to keep down vehicle weight (for fuel economy) and unsprung weight (for performance). This means thinner brake rotors.
It's MEANINGLESS what you "used to do" or did on other makes of cars.
Just measure the rotors and compare to Mercedes specification and leave expectations out of it.
ZIP/ZERO/NADA of this represents a decline in quality.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #6 of 13 (permalink) Old 06-01-2010, 06:23 PM
keyhole's Avatar
Quoted: 375 Post(s)
Whatever...
I still do not believe you when you claim that the rotor will wear out before the pads. Where did you get that information from?
post #7 of 13 (permalink) Old 06-01-2010, 09:28 PM
Quoted: 2 Post(s)
Whatever...
Why else do you suppose Mercedes publishes this figure?
Do you not think they've tested the system?
Nothing to do with "believing me" of course, just what you want to believe (based on lack of knowledge).
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #8 of 13 (permalink) Old 06-02-2010, 06:39 AM
~BANNED~
Date registered: May 2010
Vehicle: 2007 E350 4Matic P2; 2008 GL320 CDI P2
Why else do you suppose Mercedes publishes this figure?.
Minimum thickness has been published ever since disk brakes were standard on any car.
That does not answer that question of the rotors wearing out before the pads.
N_Jay is offline
post #9 of 13 (permalink) Old 06-02-2010, 08:59 AM
Musikmann's Avatar
Quoted: 6 Post(s)
I've read here that on average, the rotors will last for 2 sets of pads. But there are bound to be exceptions. Just measure them and go by the minimum thickness as suggested.
Musikmann is offline
post #10 of 13 (permalink) Old 06-02-2010, 09:59 PM Thread Starter
I checked the rotors yesterday, and there is a pretty noticable lip on them, i will change them along with the pads, thanks for the info to those of you who gave it.
    2002 c230 changing Brake Pads/rotors jelost The Discount Tire Direct Tire, Wheel, Brake & Suspension 9 06-26-2012 07:06 PM
    How to change brake pads and rotors washington dc ML W163 M-Class 6 12-05-2011 04:18 PM
    Changing my rotors and Brake pads on CLK430 myself walterf C208/A208 CLK-Class 4 07-13-2006 10:07 PM
    Noise after changing rotors and pads. bass1175 W140 S-Class 11 05-11-2006 07:00 PM
    good price on changing of stocks/springpads/rotors/and brake pads Phade C208/A208 CLK-Class 6 07-04-2005 01:30 PM
