04 e500 coolant tempriture - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-27-2010, 07:44 PM Thread Starter
Date registered: May 2010
The coolant temperature on my 04 e500 shows about 85 degrees Celsius even when i just drove a car for 5 min, is it normal? What should be a normal temperature?
thanks
rafael3000 is offline
post #2 of 3 (permalink) Old 05-28-2010, 02:47 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
That is a bit high, especially after 5 minutes!! Coolant temp sensor could be malfunctioning or there could be a cooling system problem.
mr.xpowerseller is offline
post #3 of 3 (permalink) Old 05-29-2010, 08:46 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 383 Post(s)
thanks
That sounds about right to me. I just checked mine, and it reached 85deg C after 2 miles, and then stabilized there.
You have a coolant warning light on the Instrument Cluster for very high water temp alarms. Your thermostat is set to open at 87 +/- 2 deg C which looks to be working OK.
Relax....you're OK
keyhole is offline
    04/05 E500 sport vs. 07 Acura TL type S (Are the E500 problems worth it?) jmcoy General Mercedes-Benz 18 04-09-2009 01:31 PM
    low coolant light intermittent & dim but good coolant level idkmybffcms W124 E,CE,D,TD Class 4 03-14-2009 12:47 PM
    Intrested in E500/500E, Check www.e500.org abbam W124 E,CE,D,TD Class 5 01-19-2009 07:19 AM
    PLS HELP!!! Deciding to buy either a 2003 E500 or a 2004 E500? nprakash21 W211 E-Class 12 06-19-2007 01:47 PM
    04/05 E500 sport vs. 07 Acura TL type S (Are the E500 problems worth it?) jmcoy W211 E-Class 13 02-11-2007 11:34 PM
