v230 Air Con does not work - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-26-2010, 05:32 AM Thread Starter
Date registered: May 2010
My V230 is a 1997, I had a problem when I switched the air con button on there was NO red light indicating it was functioning. So I checked the fuse which is ok. Then I noticed that the fan comes on when the switch is on (still no red light) so then I had it re gassed. The gas pressure in the refigerant system before this was ok but had it re charged/re gassed anyway. It seems that the clutch on the air con pump is not activating. Is this lickley to be a fault with the switch or the pump or something else???
clarksonv230 is offline
Air Con does not work on 1995 C280 iant62 W202 C-Class 7 07-02-2015 11:16 AM
fan blows out hot air with air con on clemmahoney V-Class 3 03-14-2010 05:01 PM
Air con ianrandom W126 S,SE,SEC,SEL,SD,SDL Class 11 06-17-2009 07:48 PM
Air con dekay V-Class 0 04-21-2007 03:20 PM
air- con WILL work , but then WON"T Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 3 06-30-2002 11:40 AM
