1982 380 sl fuel pump replace - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-24-2010, 05:54 PM Thread Starter
Date registered: May 2010
Hi
Anyone have advice on replacing the fuel pump?
THX.
kirkwll is offline
post #2 of 3 (permalink) Old 05-24-2010, 06:48 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Don't do it with a lit cigarette hanging from your mouth.
flyboyike is offline
post #3 of 3 (permalink) Old 05-25-2010, 01:52 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 381 Post(s)
Hi
You are in a General MB forum here. You have a W126 V8, and the specific forum for you is listed under MB Roadster Forum as R/C 107. There are lots of knowledgable owners there who can give you tips.
Your model is too old for my WIS, but if it is anything like the slightly later R129, the fuel pump will be located under the body, and accessible from below. You will need some little clamps to pinch off the fuel lines while you remove the old pump.
keyhole is online now
    1982 300D fuel Pump vacuum Control Valve Question dwend W123 E,CE,D,CD,TD,TE Class 1 04-28-2010 02:56 PM
    Fuel Pump Relay 380 SEC jglnyc W126 S,SE,SEC,SEL,SD,SDL Class 2 05-25-2007 04:04 PM
    fuel relay 380 sec 1982 ak380sec W126 S,SE,SEC,SEL,SD,SDL Class 2 05-05-2006 03:42 PM
    85 380 SE Fuel pump relay--where is it???! ScottP W126 S,SE,SEC,SEL,SD,SDL Class 1 04-20-2004 11:42 AM
    Where is the Fuel Pump Relay on 83 380 SEC? digsand W126 S,SE,SEC,SEL,SD,SDL Class 2 03-12-2004 10:16 AM
