SRS light - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 06-01-2010, 05:46 AM Thread Starter
Date registered: Sep 2009
Vehicle: 2004 Mercedes C240 4matic
Originally Posted by Diesel Benz View Post
Homework is always essential, even more essential when working with airbags. The light would not have come on if the battery had been disconnected while working with the steering wheel and this guidance should be easy to find.
If the battery was disconnected, then the OP could have mentioned it, every detail of background is essential when members try to help from the other side of the internet. Could be that the clock spring got broken while the OP tried to fix the horn.
Yes i did disconnect the battery.The clock spring isnt broken.I just dont understand why the light would be on but it wasnt on before. I fixed the horn(which turned out to be a bad wire going to the horn itself).
speddy is offline
post #12 of 17 (permalink) Old 06-01-2010, 05:50 AM
eric242340's Avatar
Quoted: 300 Post(s)
^Do you have a fault code reader?
ERIC.
eric242340 is offline
post #13 of 17 (permalink) Old 06-01-2010, 06:01 AM Thread Starter
I had a friend at a shop check for codes.First it didnt store any codes.Then he checked it again and it said the ignition resistance to the drivers side airbag was too high.This was about 6 months ago.He cleared the codes and the light went off.It just came back on after 6 months.I havnt had it checked for codes yet.My buddy at the shop moved out of town.
speddy is offline
post #14 of 17 (permalink) Old 06-01-2010, 06:19 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
I'm guessing the old issue reappeared because you were working with the steering wheel parts. Or you caused the issue when working with the car, I assume this being less likely.
Since you had the battery disconnected while you were working with the car, the SRS malfunction cannot have appeared because of a temporary open circuit (or short circuit). Sounds like a "real" issue that needs to be fixed, not just a code cleared.
Diesel Benz is offline
post #15 of 17 (permalink) Old 06-01-2010, 06:29 AM Thread Starter
Thanks.I'm gonna take it to the shop.I just hope it doesnt cost an arm and a leg.I'm sure it will though.Its a Mercedes ,lol.
speddy is offline
post #16 of 17 (permalink) Old 06-01-2010, 06:45 AM Thread Starter
I just spoke to a mercedes tech.He's telling me the most likely cause might be the ignition squid.Anyone know anything about "ignition squids".How hard are they to replace?
speddy is offline
post #17 of 17 (permalink) Old 06-01-2010, 07:41 AM
eric242340's Avatar
Quoted: 300 Post(s)
"Most likely" is not near enough, it needs testing properly first. Or you will spend money for nothing.
ERIC.
    SRS light stays on and SRS DTC strange result nubyOz W140 S-Class 8 11-25-2010 10:57 PM
    srs light/ bulb failure light/ warnings darraghodonnell R129 SL-Class 5 05-10-2010 10:44 AM
    2002 c 230 check engine light and srs light upstaterider2003 General Mercedes-Benz 4 08-04-2008 08:35 AM
    ABS acting up , srs light being funny , brakes weird, oil light sometimes flashes jimmypop W126 S,SE,SEC,SEL,SD,SDL Class 11 10-03-2007 07:04 PM
    battery light to srs light dim lit my90300E W124 E,CE,D,TD Class 9 01-15-2007 07:46 PM
