Kick down electric problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-21-2010, 04:01 PM Thread Starter
Date registered: Apr 2010
I got a new to me '85 300TD which runs great but the kick down doesn't work, which makes it a very slow boat when cold and in many other situations.
I checked the switch under the accelerator, I checked the fuse and I checked the solenoid on the transmission.
The problem is that no voltage appears at the switch under the accelerator, but the fuse is ok.
Seems like the cable got messed up somewhere, but where is this cable routed???
othello159 is offline
post #2 of 4 (permalink) Old 05-21-2010, 09:17 PM Thread Starter
This is amazing, I can post in this forum, just like that, but I cannot, for the life of me, get past these multiple security layers to search in this forum!!!
And then, when I would like to report this unyielding feature IT CAN ONLY BE DONE BY ANSWERING SIMILAR LAYERS OF SECURITY CODES IN ORDER TO SEND IN A COMMENT.
I think that will effectively shut down communication regarding this topic.
Apparently posting is not such a high security issue and that works....
post #3 of 4 (permalink) Old 05-21-2010, 11:17 PM
Diesel Benz's Avatar
Quoted: 37 Post(s)
I'm afraid you must learn a bit how to use the forum. You face those security questions if you try to search something from the forum when not signed in. This is obviously protection against some robots that would overload the servers from automatic, repeated search attempts.
If you are signed in and just click "search this forum" or other search options, you should not need any additional steps. This is the way it works for me at least.
Perhaps you could find your car specific forum for more help. You might also try the test forum and practise a bit before calling the forum stupid.
Welcome anyway.
Diesel Benz is offline
post #4 of 4 (permalink) Old 05-23-2010, 04:51 AM Thread Starter
Welcome anyway.
I don't think I called the forum stupid, but apparently I was, I did not understand the connection between all these cryptic questions and being logged in. Should I have read that somewhere?
In any case, thanks for the pointer, I will post the above question in the specialty forum and hopefully there is someone who knows the cabeling in this model.
    Kick Down Problem? speedbirdgb W220 S-Class 9 07-12-2010 08:07 AM
    Electric problem hansa320 W124 E,CE,D,TD Class 4 05-02-2008 08:08 PM
    560 SEC kick down problem My560SEC W126 S,SE,SEC,SEL,SD,SDL Class 19 12-13-2007 05:19 AM
    Electric side mirror problem / Seat Electronic problem taime R170 SLK-Class 8 05-24-2007 05:03 AM
    Electric transmission kick down issue, 1st gear pghguy517 W126 S,SE,SEC,SEL,SD,SDL Class 1 07-21-2004 01:17 PM
