How to fix a Merc C180 mirror turn indicator - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-20-2010, 05:37 AM Thread Starter
Date registered: May 2010
Thumbs up How to fix a Merc C180 mirror turn indicator
I own a Mercedes C180 - 2005 model.
The onboard computer reported a "faulty mirror right turn indicator" fault.
As far as I know, there are no fuses for this problem.
I was quoted South African Rand 4,000 (equiv UK Pound 380) to have the LED unit replaced!!
I decided to attempt fixing it myself.
1. Position the mirror as far as possible down and inwards.
2. Search for the release spring behind the top part of the mirror.
3. Unclip mirror and pull off mirror heating wirers. Stow safely.
4. Take the entire mirror housing and bend/flex it towards the rear of the car and towards the driver/passenger window.
5. Feel for the release clip - it is situated on the engine side of the mirror unit. Push clip with screwdriver and slide off outer mirror casing. It might need a little force to initially come off ---- not too much.
6. Note the position of the turn indicator connector plug on the mirror unit and on the LED unit. This was my problem. The connector plug was either corroded or connections were loose. I sprayed the connector with some anti corrosion/water repellent spray (Q20) and pulled/pushed connector plug a few times.
7. You may also unclip the LED unit from the mirror housing and test it.
8. Reassemble in reverse order taking care that everything fits back into position.
Hope I saved you some bucks!
ntflyboy is offline
post #2 of 2 (permalink) Old 12-06-2010, 02:39 AM
Date registered: Dec 2010
Nice instructions, I'm sure it did save us a few bucks. Took me a little while to locate the clip to remove the outer cover. Scraping the terminals on the plug did not do the trick but, as you suggest, terminal cleaner did.
remery is offline
    How to replace mirror-mounted turn indicator W211 E-Class 1 05-14-2009 06:22 PM
    merc c180 52 plate wont start!!!! badboy1976 W203 C-Class 11 03-19-2009 01:52 PM
    Help needed: Turn Indicator on CLK wont turn off aussyfiddy C208/A208 CLK-Class 2 11-09-2008 11:57 PM
    Merc C180 Poor Cold Start dmc1000 W203 C-Class 1 09-06-2006 03:37 PM
    I really need to fix my merc mbNZ W201 190-Class 3 08-16-2005 09:24 AM
