Door Open Indicator - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-17-2010, 06:07 PM Thread Starter
Date registered: Dec 2009
Door Open Indicator
The door open indicator goes off and on continually on my 2005 C230. The doors aren't open. Can I do something to disconnect it without having to take it into the shop?
kmantle is offline
post #2 of 4 (permalink) Old 05-17-2010, 10:39 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Why would you want to "disconnect the door open indicator"? Perhaps you can fix it, if not, then le someone else fix it.
What have you checked so far? I would start from the door switches, use a temporary buffer to test if the switch just opens from body movements while driving, this sometimes happens.
Diesel Benz is offline
post #3 of 4 (permalink) Old 05-18-2010, 08:33 AM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
If you are too cheap to fix a door open sensor, then you should just sell the car now and go buy a Hyundai or Kia.
mr.xpowerseller is offline
post #4 of 4 (permalink) Old 05-18-2010, 10:06 AM
Quoted: 35 Post(s)
Often it does not even need new parts, I believe there is even an official bulletin that explains how the sensor is "raised" to better reach the door. Of course the sensor tap could be broken too in which case a few dollar's switch needs to be replaced.
    Retrofit window open/door open feature on 2001-? stim141 C208/A208 CLK-Class 2 01-27-2010 04:40 PM
    No open door light indicator cal45fan W163 M-Class 8 02-21-2007 11:41 AM
    Door open indicator light? allerton W126 S,SE,SEC,SEL,SD,SDL Class 7 09-19-2006 11:29 PM
    s550 problem- no door open indicator sl owner W221 S-Class 10 05-24-2006 03:33 PM
    Any opinions on why MB doesn't have a "door open" indicator on the ML? Darkmann W163 M-Class 4 10-31-2002 09:42 AM
