Question about my C220 - Need An Answer - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-14-2010, 12:38 PM Thread Starter
Date registered: May 2010
Post Question about my C220 - Need An Answer
Hello all, I am new to these forums. I had a question regarding my 1995 Mercedes C220. I bought it a few days ago with about 294k on it. Car runs smoothly, no problems with the breaks, accelerator runs beautifully. The only problem I have been having is that every time I turn the car off and my lights, speaker system or anything else was still on before I turned it off, it stalls when you try to turn it on again (or even having my gas on the break pedal before turning it off) At least that's what I have noticed before it won't turn on again. All it needs it a simple boost from the booster cables after that and she's up and running again with no problems. Although not a huge problem, it is very inconvenient. Is the battery too weak to handle my speaker system?
Also, the SRS light is on, any suggestions?
A prompt answer would be appreciated.
Thanks
ilya67 is offline
post #2 of 4 (permalink) Old 05-14-2010, 01:49 PM
Musikmann's Avatar
Quoted: 6 Post(s)
If you don't know how old your battery is I would replace it. Or take it somewhere to have it load tested. Your SRS light might be due to a defective pad in the passenger seat cushion. On my car it inactivates the airbag on that side when a child (or someone weighing less than 70 lb) occupies the seat. A fresh battery might take care of that too.
Musikmann is offline
post #3 of 4 (permalink) Old 05-14-2010, 01:56 PM Thread Starter
Thanks for the fast response. My battery was tested yesterday, the mechanic said the battery is super good. Could it just be that the battery is weak?
ilya67 is offline
post #4 of 4 (permalink) Old 05-14-2010, 02:09 PM
Musikmann's Avatar
Quoted: 6 Post(s)
You're welcome.
Are you asking if it might have less than the required cranking amperage? That might be, check it and your owner's manual to see if it has the correct specs. Or if you can't find the info on the battery maybe a tester can tell you.
Maybe you can help answer my question? cheryl7158 General Mercedes-Benz 7 03-10-2008 03:37 PM
Can someone answer this question? lilphatboi W204 C-Class 3 12-06-2007 10:41 PM
No answer to this question... slknow R170 SLK-Class 8 03-01-2005 05:42 PM
can someone answer this question? BIGGS2288 W124 E,CE,D,TD Class 6 11-29-2004 12:20 AM
Please Answer This Question avijay Audio & Telematics Forum 4 06-25-2003 10:37 PM
