used mb gearbox dipstick to check level and oil is diff colour - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-13-2010, 03:17 PM Thread Starter
Date registered: Sep 2009
i bought atf from mb i gave them my vin number and the oil theu gave me is red, when i dipped the gearbox it was clear/yellowy colour, is this ok
4nd1 is offline
post #2 of 6 (permalink) Old 05-13-2010, 03:24 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Most of the newer ATF is backwards compatible. What type of MB do you have and how old is the fluid? If it's been in there for 40,000+ miles I'd change it completely to the newest compatible fluid plus the filter if you have one. I'd also check for a leak in the system.
Musikmann is offline
post #3 of 6 (permalink) Old 05-13-2010, 03:32 PM Thread Starter
hi thanks for reply, i have 2005 clk 500 it has done 60,000 miles, so will they mix ok
4nd1 is offline
post #4 of 6 (permalink) Old 05-13-2010, 06:31 PM
joshuajeeper's Avatar
Date registered: Sep 2006
Vehicle: 1985 Mercedes 300TD, 2014 GLK250 Bluetec
HOLD ON!!! If you have a 2005 CLK500 then you have the 7speed transmission. Which does NOT have a dipstick. You fill the transmission through the drain plug with a special tool. The yellowish/clear fluid that you checked is your engine oil!!! The transmission fluid is red and the more miles there are on it, the darker it gets. NOT yellow.
1985 300TD - "Panzer Wagen" - undergoing full restoration (resto - mod)
2014 GLK250 Bluetec (Wife's Car)
Mercedes-Benz Master Certified Technician.
http://www.flickr.com/photos/joshuajeeper/
joshuajeeper is offline
post #5 of 6 (permalink) Old 05-14-2010, 12:48 AM Thread Starter
Sorry its the 2003 clk 500 i have , the filler/dipstick plug is next to the engine oil filler but lower down, but it has made me wonder why is the atf in there not red like the atf i got from mb, since ive put the atf in the car pulls away fine and theres no slipping anymore but i havent driven it just tried it on my drive way
4nd1 is offline
post #6 of 6 (permalink) Old 05-16-2010, 03:30 AM
keyhole's Avatar
Vehicle: 2004 CLK 240 Coupe
Quoted: 385 Post(s)
Originally Posted by 4nd1 View Post
..... but it has made me wonder why is the atf in there not red like the atf i got from mb, ......
rest assured...the red dye in your new ATF is not permanent. As the fluid ages, it may become darker or become brown.
btw, when you check the ATF level, sniff the fluid on the end of the dipstick. If it smells like burnt toast, the fluid has 'cooked' itself and is no longer capable of providing proper lubrication for the transmission. At that point it must be replaced, or expensive gearbox maintenance is assured.
5-speed gearbox 722.6xx, requires MB 236.10 ATF 3403.
A 1001 989 2303, or 2103.
7 speed gearbox 722.9xx, requires MB 236.12 ATF 3353
A 001 989 4503.
explorerfl likes this.
keyhole is online now
    Oil Change & Oil Check Level (Reduce Oil Level) jjleonard W211 E-Class 21 10-06-2010 08:52 AM
    Checking Engine Oil Level with the DIPStick slybydesign W210 E-Class 4 06-29-2007 04:23 PM
    dipstick comparison, surprise, oil level speculation, prediction fgwinn R171 SLK-Class 3 08-26-2005 07:17 AM
    Auto gearbox level check? mark1668 W140 S-Class 2 03-11-2004 07:40 AM
    Dipstick oil level shrimpton W126 S,SE,SEC,SEL,SD,SDL Class 6 09-04-2002 12:57 AM
