Fauly Wiper - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-09-2010, 12:09 PM Thread Starter
Date registered: May 2010
Fauly Wiper
Really need inspiration here. My 1995 C220 windscreen wiper comes on intermitantly, even when switched off.
There is no auto sensor or anything like that. The arm also extends out, leaving the blade catching on the outer frame.
It is driving me mental and I am ready to rip it off.....help
FightingMicrobe is offline
post #2 of 4 (permalink) Old 05-10-2010, 06:27 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Faulty multi-function switch and/or wiper relay would be my suspects.
flyboyike is offline
post #3 of 4 (permalink) Old 05-10-2010, 09:12 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 343 Post(s)
Originally Posted by FightingMicrobe View Post
..... The arm also extends out, leaving the blade catching on the outer frame.
You mean in the Park position, right?
That's not correct. It could be worn wiper linkages, or a mal-adjustment of the motor. Can you feel any slack/backlash if you lift the wiper arm?
Was it overloaded in winter with clearing snow?
keyhole is offline
post #4 of 4 (permalink) Old 05-11-2010, 07:17 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
It sounds like a combination of both suggestions. The worm gear can get damaged if not lubricated periodically or some other damage to the cam, which would cause the arm not to retract all the way when it parks. Just to be sure, you didn't replace the blade recently, possibly getting one that is too long? That would be a simple fix but I don;t think it;s your issue. Getting back to the problem, when your wiper is on do you notice it moving in and out as it wipes across the windshield? If it only sweeps but doesn't follow the cam movement in and out then you do have a more serious issue. This would describe the sticking problem. Coming on by itself would be symptomatic of the combination switch.
The Coupe Group on Facebook
DirectLA is offline
    Wiper Motor and Wiper Control Common with Other Models? MN190 W201 190-Class 1 03-25-2010 10:12 AM
    Wiper goes on by it self. Ronsbenz W210 E-Class 7 12-30-2009 07:02 AM
    Help! Removing 300E Wiper And Headlight Wiper! HaikuMarko W124 E,CE,D,TD Class 1 12-03-2009 09:49 PM
    Is the retail 24" Bosch MicroEdge wiper blade the same as OEM wiper? MustMakeAmends W124 E,CE,D,TD Class 6 04-05-2007 04:57 PM
    WTB: W126 Euro Headlamp Wiper Motor/Wiper Arm cyberdyne For Sale/Wanted/Trade/Giveaway 1 02-07-2007 01:24 PM
