A class error message - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 05-05-2010, 02:38 PM Thread Starter
Date registered: May 2010
Hi
I recently bought a A190, 2000 secondhand and I have no owner manual. In the screen that usually shows the miles done and temperature, a oil can light and the word "Hi" appeared. Does anyone now what this means? The normal oil light is at the top and red, so I dont think its the oil though. Any help would be much appreciated! Thanks! ... and do you know where I can get a manual? (then I wouldnt have to ask stupid questions )
vlel is offline
post #2 of 8 (permalink) Old 05-05-2010, 10:03 PM
Diesel Benz's Avatar
Quoted: 40 Post(s)
Originally Posted by vlel View Post
Hi
A user manual is a spare part and you can purchase one from your dealer.
I assume "Hi" does not mean Engine is saying hello to you but instead the car is telling oil level is high but I do not have a copy of the user manual for this car and I may be wrong.
Welcome to the forum.
Diesel Benz is online now
post #3 of 8 (permalink) Old 05-06-2010, 01:16 AM Thread Starter
hahaha, I realised the car is not greeting me! I dont know too much about cars, but I thought oil is a problem when it is low? Can high oil be a problem?
vlel is offline
post #4 of 8 (permalink) Old 05-06-2010, 05:20 AM
Sith Lord
elbeik's Avatar
Date registered: Sep 2009
Vehicle: 72 280SE 88 560SEC 92 E500 6.0 95 SL320 14 GLK350
Quoted: 217 Post(s)
Oil should be at recommended level; there are markers for min/max levels on the dipstick, engine compartment.
elbeik is offline
post #5 of 8 (permalink) Old 05-06-2010, 05:24 AM Thread Starter
Great! Thanks. This really helps. So we need to tap off some of the oil. Is this something I (or rather my boyfriend) can easily do or would you advise us to go to a dealership?
vlel is offline
post #6 of 8 (permalink) Old 05-06-2010, 05:26 AM
Sith Lord
elbeik's Avatar
Quoted: 217 Post(s)
First ensure that you do have more oil than required in your engine. Any mechanic can check it; and any mechanic can drain it for you.
elbeik is offline
post #7 of 8 (permalink) Old 05-06-2010, 05:30 AM
eric242340's Avatar
Quoted: 312 Post(s)
First check the dipstick to see how high the oil level is and then drain a little and check again then repeat the procedure until the level is within the parameters on the dipstick.
ERIC.
eric242340 is offline
post #8 of 8 (permalink) Old 12-07-2010, 12:16 AM
criszoe's Avatar
Date registered: Dec 2010
Vehicle: Mercedes A190 Avantgarde
Viel Im new here but have had a similar problem. this post is a few months old and you must have fixed it by now but in case anyone else reads heres my bit.
When the ignition is turned on to position 2 and all the lights come on wait for a few seconds and an error picture comes on of an oil can press the 000 button twice with in a second and it tells you the oil level. 1 1.5 2 liters oil needed or HI saying you have too much oil which can cause an alarm to sound when at running temperature. having too much oil is bad for the car and one of the usual problems occurring is cat converter problems. loosen the sump plug and drain some oil out but if you dont want to change the seal ring on the plug use a windscreen wiper tube and insert into the dip stick tube and syphon some oil out. you will need to get the error message turned off by a mechanic afterwards. by memory i was told the difference from low and full on the dip stick is 1 litre.
criszoe is offline
E2 error message mercjason Audio & Telematics Forum 0 05-12-2008 11:17 AM
Error message mike69 W210 E50 AMG, E55 AMG 4 04-16-2008 08:07 AM
Error Message tlbenz W211 E-Class 4 01-18-2007 07:14 PM
error message. vitd W210 E-Class 1 12-01-2005 07:21 AM
cd error message rambo006 W140 S-Class 0 02-19-2005 05:59 AM
