Air sampler buzz near sunroof/rearview mirror - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-01-2010, 09:15 AM Thread Starter
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
I posed a couple of questions on the W202 forum but no-one seems to know the answer so I thought this surely applies to other models as well.
The air sampler in many 1990's and 2000's vehicles has a small vent usually located in the overhead console contained within or near the attachment point of the rearview mirror. Sometimes a buzzing sound will be heard in this area and some claim that it comes from the Air Sampling Motor or Aspirator which is located under the console itself. The blower is separate from the small fan or sensor that is beneath the vented section visible from the cabin when looking at the mirror attachment.
I am curious about a few things, such as is there a sensor or a fan under the vent and what is that part called or the part #? The motor is separate and can be seen in the original thread I am linking below. Also, as I asked there, for those of us with the manual controlled HVAC does this air sampler actually serve any purpose since our AC/heater doesn't adjust itself automatically? I know sometimes a system is put in place even if it isn't used because it's cheaper to do so that to make two versions, like when non-power seats have all the wiring and harnesses just not the motors if the power seat option isn't ordered. Can those of us with the manual HVAC unplug the sensor/motor to stop the buzzing without any issue?
Partsgeek describes the motor as "Temperature Sensor For temperature sensor ventilation on roof rail. Draws air from a specific location in vehicle to sample the temperature and relays information to control unit which takes action to correct to desired temperature setting." Again this seems unnecessary on a manual HVAC. Thanks for any info!
The Coupe Group on Facebook
DirectLA is offline
post #2 of 3 (permalink) Old 05-06-2010, 12:22 PM
jet606's Avatar
Date registered: Apr 2010
Vehicle: 1999 E300TD: 302,000 kms. 2002 Golf TDI, 385,000kms, winter beater, parked for the summer.
it's called a "sampler blower motor" pn W0133-1609370. it is used to send signal to the auto temp controller by continously sucking cabin air thru the little vent hole across a temp sensor.
don't know about manual hvac system purpose of the fan, might be like you said, redundant. just disconnect it and see what happens. mine has auto temp, every time i vaccuum the car, i just stick the vaccuum onto the inlet for a few seconds. these things accummulate alot of dust over time, makes for slow auto temp response.
jet606 is offline
post #3 of 3 (permalink) Old 05-06-2010, 04:56 PM
Musikmann's Avatar
Quoted: 5 Post(s)
I agree with jet606, unplug it to get rid of the noise. With your manual HVAC I see no purpose for it.
Musikmann is offline
    RearView mirror Mr2weenie W140 S-Class 14 04-05-2012 10:44 PM
    A buzz around the sunroof switch Matt09 W202 C-Class 10 04-30-2010 11:22 AM
    buzz/humming noise from near rearview mirror/sunroof button AMGSingh C208/A208 CLK-Class 2 02-18-2010 10:42 AM
    96 c280 sunroof switch area buzz wolffbenz W202 C-Class 6 11-21-2008 09:42 AM
    Rearview Mirror??? fata1ity W124 E,CE,D,TD Class 4 01-11-2008 07:22 AM
