Accelerator pedal seems to stick a bit - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-30-2010, 09:22 AM Thread Starter
theblueprince's Avatar
Date registered: Dec 2008
Vehicle: E 300D 1995
Is there a basic way to lubricate the accelerator pedal, or is this something in the linkage area of the fuel delivery system that I should lubricate? Just wondering if spraying some lubricant on the actual pedal will change anything.
THank you.
theblueprince is offline
post #2 of 2 (permalink) Old 04-30-2010, 01:18 PM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 152 Post(s)
Linkage lube
Don't bother with the pedal. Get under the hood with a big flat blade screwdriver and twist-pop each mechanical linkage joint apart. Clean and relube then squeeze back together with channel lock pliers or something like that.
The lube fluid is somewhat controversial. Some use transmission fluid, some use light oil. I use a small smear of white waterproof grease. It's all good.
Let us know how you make out.
rocky raccoon is offline
    Accelerator pedal sweeper W163 M-Class 4 06-10-2009 04:24 PM
    Accelerator pedal Willber14 W126 S,SE,SEC,SEL,SD,SDL Class 9 02-25-2009 07:27 PM
    Accelerator pedal??? Tarak V-Class 1 05-09-2008 06:04 PM
    Accelerator Pedal larryk R170 SLK-Class 6 07-30-2005 01:42 PM
    Accelerator Pedal? digsand W126 S,SE,SEC,SEL,SD,SDL Class 2 07-16-2004 11:20 AM
