300TDT SLS? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-28-2010, 12:50 PM Thread Starter
Date registered: Apr 2010
300TDT SLS?
Good afternoon all. This is my first post, I did a search and couldn't find the answer I'm looking for. I'm THIS CLOSE (holding fingers real close together) to pulling the trigger on a W123 wagon. I'm looking at one on eBay right now and the rear end is sagging, I'd guess 4-5 inches low. He says it's because there is some weight in the rear (I'd estimate less than 100 lbs). I call phony. He says the car does not have SLS, is there a way I can find this out? I have the VIN # WDBAB93A5CN006518. Any help would be appreciated.
DrBoost is offline
post #2 of 4 (permalink) Old 04-28-2010, 04:10 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
I had a 1985 123 300TDT and it had level control, I think all wagons have/had it. I would think 100 lbs would not cause it to sag, I have had 600 lbs in the back and it would sink 2 inches and rise very slowly when started, you are off on a likely problem issue.
Peter Guenther is offline
post #3 of 4 (permalink) Old 04-28-2010, 04:18 PM
sd300td's Avatar
Date registered: Dec 2008
Quoted: 10 Post(s)
All w123 wagon's came factory equipped with SLS. The seller either doesn't know a thing about these cars or is flat out lying. This one does have SLS still installed, and it needs work. The WVO tank might cause that sort of sagging, especially after the car hasn't been run for a day or two. Still, my guess is something is wrong with the SLS.
Regardless, unless you want an WVO car, find another. The cool things about this particular wagon is the roof rail delete (or maybe they're just gone), and the third row seat.
The WVO is not something I would pay a premium for; quite the opposite actually. Another huge negative for me is the incorrect rear bumper, which screams prior body damage not to mention not road-legal minus back-up lights.
Not worth much more than the current bid IMO.
http://cgi.ebay.com/ebaymotors/300-T...item255a2d8b4f
2005 230 K, 26k-77k (sold)
1982 300 TD, 167k-226k
1982 240 D, 308k-327k (sold)
1998 E 320, 120K-141K
sd300td is offline
post #4 of 4 (permalink) Old 04-28-2010, 08:12 PM
Kajtek1's Avatar
Quoted: 1250 Post(s)
Inspect it before buying. I know that is sometimes hard on ebay.
On my 1985 wagon -years ago I had the hydraulic hose deteriorating and leaking the suspension fluid out.
Cost me $30 for the hose and $20 for the fluid to fix it.
Kajtek1 is offline
    W126 SLS and w123 SLS DieselKraut W123 E,CE,D,CD,TD,TE Class 15 10-12-2011 05:43 AM
    H&R Spring parts no. for w/SLS and w/o SLS biondi W126 S,SE,SEC,SEL,SD,SDL Class 18 07-20-2011 08:37 PM
    H&R Springs, SLS vs. Non-SLS Sauber W126 S,SE,SEC,SEL,SD,SDL Class 12 06-06-2010 08:54 PM
    seeking sls hard lines 87 300TDT wagon quinny W124 E,CE,D,TD Class 2 04-03-2009 07:24 AM
    FS: Highly machined SLS plug for 16valve SLS delete waybomb For Sale/Wanted/Trade/Giveaway 0 09-06-2007 05:41 PM
