05' C240 4MATIC Parking Brake Lever - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-23-2010, 11:47 AM Thread Starter
Does anyone know the part number for the parking brake lever assembly. Mine is no longer ratchiting even after adjusting the parking brake cable through the panel under the rear seat. The light wont stop coming on and the beeping at ever stop is driving me crazy!!! please help..
if needed my VIN ends with F710104
thank you in advance
bart1man2 is offline
post #2 of 4 (permalink) Old 04-24-2010, 08:14 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 375 Post(s)
I cannot help you with a part no for a complete assembly - but I am surprised that you have run out of adjustment of the cables...
Are you sure that you moved the slack adjuster (under the rear seat) in the right direction? There is also another adjustment inside each rear wheel brake drum. A small adjusting wheel is on each brake assembly.
Parking brakes systems are not expected to wear out. Maybe something has come adrift on your pedal assembly, but it's hard to believe that you need a new one. Would a WIS drawing help?
keyhole is offline
post #3 of 4 (permalink) Old 05-09-2010, 08:59 AM Thread Starter
I believe it is the lever becuase there is no more "ratchet" available in the pedal...when I pull the release handle the foot pedal stays still and when I pull on the foot petal even slowly there is only about 2 to 3 clicks and then nothing and if you let go even slowly the foot pedal drops back all the way down.... That is why I am thinking I need a new pedal foot assembly...
post #4 of 4 (permalink) Old 05-09-2010, 10:09 AM
keyhole's Avatar
Quoted: 375 Post(s)
OK - you may be right. The pedal mechanism could be toast.
Here are some WIS pages to study.
1. Details of the two versions of the pedal. You should have the latter version introduced 09/2002: with pulled notch.
2. Details of how to adjust the parking brake cables.
3. Details of how to adjust the parking brake shoes at the wheel.
keyhole is offline
    What kind of brake fluids does my 2003 c240 4matic need? dg45 W203 C-Class 1 08-14-2009 01:36 AM
    How to change a Turn Signal Lever in a 2004 C240 4Matic Stocks3019 W203 C-Class 3 05-10-2009 11:13 AM
    HELP! 460 parking brake lever needed Hipine G-Class 14 06-01-2004 02:06 PM
    SQUEAKY PARKING BRAKE ON 2002 C240 Guest (MBNZ) W203 C-Class 2 05-20-2002 09:19 AM
    Have you got any close-up of brabus gearshift lever & hand-brake lever as picture? Marcello (Piacenza - R170 SLK-Class 12 04-04-2002 09:22 AM
