Problem with my ML430 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-22-2010, 12:03 AM Thread Starter
Date registered: Apr 2010
I have a problem with my ML, it is a 2000 model, got 91 thou on the clock and all of a sudden it is trying to die on me when I drive it. From low speed when the engine is at normal running temp, when you go to accelerate the engine dies right doen the revs dip and then the car decides it wants to go then it goes......for example when your travelling and you deaccelerate then press the pedel again the eingine dies right down and almost splutters, then it selects its gear and goes. also when the car is stationary if you press the gas pedel then again the engine almost dies first and splutters then the revs pick up. when driving i thought it might be the a/t but its doing it when the car is stationary too. Note also thought this does not happen all of the time, just sometimes. please help me as I don't know what it could be.
Many thanks.
Mike Beddows is offline
post #2 of 2 (permalink) Old 04-22-2010, 12:11 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
The usual suspect is crankshaft position sensor.
You can search for this and probably find a lot. Note that ML320 and ML430 use same sensor.
Kent Christensen
'07 GL320CDI
lkchris is offline
    CD Changer problem with 01 ML430 hksnlper W163 M-Class 1 01-19-2010 05:42 PM
    01 ML430 TeleAid Problem dean1969 W163 M-Class 3 08-01-2006 07:47 PM
    '01 ML430 Navigation problem jaydee427 W163 M-Class 2 11-25-2005 12:28 PM
    Problem on '99 ML430 MillTek W163 M-Class 1 10-04-2003 09:18 AM
    Help with ML430 and S500 problem. I-Drive-Benz Audio & Telematics Forum 1 06-13-2003 05:52 PM
