1998 E430 Catalytic Converter noises - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 04-20-2010, 05:58 PM Thread Starter
Date registered: Jan 2008
Vehicle: 1998 E430; 2005 CLK500; 1981 Porsche 911SC; 1976 Porsche 914; 1974 Porsche 914; 1972 Porsche 914
There is one He** of a racket coming from my catalytic converter. What could be causing this, and where is the best place to purchase the new one?
Thanks.
Christian
rebelmdot is offline
post #2 of 10 (permalink) Old 04-20-2010, 07:29 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
Has someone been running 87 octane gas? Better get the high limit credit card out because a new cat is NOT the slightest bit cheap. You are looking at $820 for the right and $1140 for the left, plus installation.
mr.xpowerseller is offline
post #3 of 10 (permalink) Old 04-20-2010, 08:07 PM
Musikmann's Avatar
Quoted: 6 Post(s)
If you are not in California you can buy a 49 state compliant cat and have it welded in for a couple of hundred. Check out the stickys on the W210 forum (that's what you have) and look for the one on aftermarket cat replacement. Good luck and welcome to BW.
Musikmann is offline
post #4 of 10 (permalink) Old 04-20-2010, 08:23 PM
72benzyacht's Avatar
Date registered: Apr 2010
Vehicle: Master Technician Mercedes benz 11 years
Check with your dealer. I think the price recently went down to around 400 bucks for those cats. There super easy to change out. Too bad you out of the 8year 80k goverment mandated waranty replacement. I do highly recomend replacing it because when the catlyst inside the exhaust becomes loose like that and starts ratteling it can turn sideways and block the exaust causing that entire bank to missfire. : (
2011 ML350
2000 C230 sport (modded)
1972 SEL 280 4.5 (sold)
2010 E350 (sold)
2009 E550 (sold)
2007 E350 (sold)
72benzyacht is offline
post #5 of 10 (permalink) Old 04-20-2010, 08:41 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Mine went bad before the 8/80,000 elapsed so were covered by the warranty. That was about a year ago and at that time dealer price was $1200/side for the entire pipe running from the exhaust manifold back to the muffler. If they have come down to $400/side that's thae way I would go.
post #6 of 10 (permalink) Old 04-20-2010, 09:28 PM Thread Starter
Thanks
Thanks everybody, and no, no 87 here, only 93 since I have owned the car.
post #7 of 10 (permalink) Old 04-20-2010, 11:03 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 695 Post(s)
Could be a broken bracket, but more likely a baked cat, which will require replacement.
GeeS is offline
post #8 of 10 (permalink) Old 04-21-2010, 10:12 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Where to purchase
Sorry I overlooked this question. Several W210 owners have bought Magnaflows and all seem satisfied. Again, check the W210 forum stickys and there are a couple of threads discussing the options
post #9 of 10 (permalink) Old 04-21-2010, 12:12 PM
jsap's Avatar
Date registered: Jun 2008
Vehicle: R129
Thanks.
Christian
If you bang on each of the 4 cats, and any of them is rattling, just make sure it's not an issue with the aluminum heat shield being bent or some other metal contact. You could also have a broken rubber hanger somewhere.
But, if the sound is like little pebbles inside the cat, then I'd replace the cat now. When this happened to me, the car continued to run for two years, but the performance degraded VERY SLOWLY and imperceptibly, until finally I got a check engine light and misfires.
I took the thing to a mechanic I checked out on Yelp as being a good guy, and was also a former foreman at a local Mercedes Dealer, but I got had. I told him the car is rattling, and you could clearly see the dented cat (it bottomed out on a freeway on-ramp a few years ago). But, he insisted that it was the Transmission Control Module. I argued back, but he kept insisting that the repair needs to be done right. So, after much back and forth, he twisted my arm enough for me to drop $1100 on a new TCM/labor.
Well, that didn't fix it, so he then recommended that I change the cat, and he knew the perfect guy! WTF! So, I took the car away from this idiot to a reputable muffler shop of my choice. I pointed to the dented and rattling cat, and after a few minutes of cutting and welding, ALL the power returned, and all was good.
Lesson learned for me: If a cat's rattling, just take it to a good muffler shop, and bypass the "expert" advice.
Also, I've heard that the Mercedes cats have come down in price, so check around before you get an aftermarket. I have a CarSound/Magnaflow secondary, but next to the OEM, it's not pretty.
John
jsap is offline
post #10 of 10 (permalink) Old 04-21-2010, 04:51 PM
Date registered: Jun 2009
Vehicle: 1991 300E
You sure do seem convinced on the octane killing the catalytic thing and of course you've got many here who believe the same. While I am no expert, that doesn't seem to be a very likely scenario at all.
One well regarded indy, Jonathan Hodgman of Blue Ridge Mercedes/AMG East (jhodg5ck on this forum), says: "IME, I have Never seen lower octane fuel hurt a cat." In fact, he uses 87 octane in his commuter wagon. His comments can be found here: Should I be running Premium fuel? (post #15)
Other experts seem similarly unconcerned about octane level. Below are some interesting quotes from "Why use premium gas when regular will do?," USA Today, July 30, 2003:
I personally use regular even though my owner's manual says you'll get better performance with premium," says Lewis Gibbs, consulting engineer and 45-year veteran at Chevron oil company. He's chairman of Technical Committee 7 on Fuels, part of the Society of Automotive Engineers (SAE) Fuels & Lubricants Council.
I go back and forth, and I'm hard-pressed to notice" whether there's regular or premium in the tank, says Jeff Jetter, principal chemist at Honda Research and Development Americas. He drives an Acura designed for premium.
Our cars must be able to drive all over the world, and so we are able to run on regular," says Jakob Neusser, director of powertrain development at Porsche's research and development center in Weissach, Germany. "You don't have to feel that a mechanical problem or anything else will happen" using regular gas, even in the highest-performance, regular-production Porsches.
That same article goes on to say that the quality of the fuel is the most important factor, not octane. Carbon build-ups and other issues can contribute to the demise of a catalytic converter, but not octane.
In "The Low-Down on High Octane Gasoline," the Federal Trade Commission notes:
As a rule, high octane gasoline does not outperform regular octane in preventing engine deposits from forming, in removing them, or in cleaning your car's engine. In fact, the U.S. Environmental Protection Agency requires that all octane grades of all brands of gasoline contain engine cleaning detergent additives to protect against the build-up of harmful levels of engine deposits during the expected life of your car.
From "Do You Really Need Premium ," Edmunds.com, August 20, 2007:
Until about 15 years ago, if a car called for premium gas and you pumped in regular, the car began to knock and ping and even vibrate. But that was before they essentially put a laptop under the hood of the automobile, said Dr. Loren Beard, senior manager of Environmental and Energy Planning, for Daimler Chrysler. Now, sensors take readings and tune the engine as you drive by adjusting the timing for whatever fuel you put in the tank.
The result is that a car that calls for the mid-grade gasoline will usually run on regular without knocking, Beard said.
Steve Mazor, principal auto engineer for the Auto Club of Southern California, said it is important to read the owner's manual carefully. The key is to figure out whether premium gasoline is "required" or "recommended." If it is recommended then a driver could opt to use a lower grade of gas, if they were willing to accept slightly reduced performance and fuel economy.
Volvo cars call for "premium fuel [91 octane or better] for optimum performance and fuel economy," said Wayne Baldwin, product/segment manager for the S60/S80. "However, there is absolutely nothing wrong with using 87 octane, as the knock sensors and engine management system 'protect' the engine from knocking."
Edmunds.com had a Volvo S40 in its fleet, so we consulted the owner's manual to see the exact phrasing in regard to fuel requirements. It said, "Volvo engines are designed for optimum performance on unleaded premium gasoline with an AKI (Anti Knock Index) of 91 or above. The minimum octane requirement is AKI 87." It appears that Volvo is making a recommendation for premium gas but is not requiring it.
The "Mercedes-Benz W124 (200, 200E, 230E, 260E, 300E, 230CE, 300CE, 260E4MATIC, 300E4MATIC) Owner's Manual," pdf download via mediafire.com, states: "For knock-free operation the engines have to be run on fuels which have the minimum octane ratings: . . . . Unleaded premium fuels 95 RON/88 MON minimum." In the United States, Canada and some other countries, the number on the pump is the average of the RON and the MON. In this case 91.5 octane would seem to be the factory requirement, depending on how you read it.
In "13 Must-Know Tricks to Max Out Your Road-Trip MPGs," Popularmechanics.com, author Mike Allen suggests:
Fill up with the fuel that has the recommended octane rating (let's assume it's 91) and drive for a few tankfuls. Check your fuel economy by dividing the miles driven by the amount of fuel consumed.
Now try a midgrade fuel and repeat. Make sure the driving route, traffic and weather conditions are similar. If the fuel economy is just about the same, try the next lower grade. Repeat until you see a drop-off in mpg. When you do, go back up one grade (to the one that didn't lower economy) for the best mileage.
Now, instead of dividing by the gallons consumed, divide by the cost of each tankful. This will give you the miles per dollar. If you are still saving money, reserve that better gas for times when you really need performance--like for towing.
I have followed this testing model in my own 1991 300E since buying it in June of last year, tracking the data in a spreadsheet. I logged over 40 tankfuls, well distributed between 93 and 89 octane, before even glancing at the results. Now with more than 60 tankfuls logged, still well distributed, I can say conclusively that I get 1-2 mpg better results with 89 octane than with 93 octane. Meanwhile engine temperature and oil consumption remain identical. This indicates that the engine is performing more efficiently with the lower octane fuel. And of course the fuel cost per mile is lower as well. I drive fairly hard, my mechanic friends tell me, and I have yet to hear a knock. Running 93 octane, I get about 320 miles per tankful. With 89 octane, I routinely get 340 miles a tankful or better. Recently, I got my first 400 mile tankful.
Most all of the user comments on octane I have seen on this forum have been opinions based on experience, usually second-hand and anecdotal. There are many horror stories passed along, failing catalytic converters, fuel injectors, clogged lines and more. However, in most of those stories the cause of failure is suspect or patently unrelated to octane. Few users are citing data and fewer still are acknowledged experts. As one poster to this thread says in his signature: "One anecdotal story does not constitute a statistic."
Note that all bolding and italics above is mine. Underlining indicates links to the sources cited.
Please excuse the length of this posting, but octane myths and flame wars are too common on this board. Users come here for accurate and helpful information on the operation and maintenance of their Mercedes. I feel that there is an obligation to call out postings that are inaccurate and not factually-based.
Pump what you like. Flame as you feel compelled.
300E91 is offline
    Where is the catalytic converter? El Prez W140 S-Class 3 01-21-2010 08:37 AM
    New catalytic converter frobi W124 E,CE,D,TD Class 11 01-22-2009 08:25 PM
    2000 E320 Wagon Rattling Noise...Catalytic Converter/ROUGH IDLE PROBLEMS AND NOISES!! peter18 W210 E-Class 27 10-08-2008 06:47 PM
    Catalytic Converter daniald W210 E-Class 3 05-16-2008 11:30 AM
    e430 Catalytic Converter - Help! Jay_R W210 E-Class 27 03-11-2008 08:10 AM
