87 300E broken middle door hing. Please Help - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-19-2010, 04:07 PM Thread Starter
Date registered: Apr 2010
Hey guys I own a 1987 MB 300E. The past couple of weeks the driver side door has been sticking on me when I open it. Well today I went to close my door and it wouldn't close. I don't know the name of the part but it appears to be a middle hinge, a flat piece of metal, that slides inside the door when you close it. There is a large upper and lower hinge but this one is between them. It has bent and cracked in half so when I attempt to close the door it bends and prevents it. How do I replace it? What is it called? Can I get it at any parts store? Do I even need it? I'm not sure of its function. Seems like the other larger hinges hold the door on. What would happen if I just cut it out so the door would close? Please help. I am having to crawl in through the pasenger side. Here is a pic of the good one on the passenger side.
Name:	door hinge.jpg
lhill3580 is offline
post #2 of 3 (permalink) Old 04-20-2010, 01:53 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
It's called the check strap.
They all break eventually.
Get a new one.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 3 (permalink) Old 04-20-2010, 03:14 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
You can probably get it on line, but I doubt that you can get it locally. I would stop using the door because it can damage the window track and put a dent in the door panel. It is reasonably easy to change but the door panel needs to come off. I you cut it, the door could hit the fender, I got one for my 140 at MB for $35
This is how it is done on a 140
PeachPartsWiki: Replacing Door Checks
Peter Guenther is offline
Door Armrest Broken odbII W203 C-Class 4 12-01-2011 07:26 PM
R350/2006 middle seat for middle row VICTOR52 W251 R-Class 31 09-09-2011 09:55 AM
cls middle door panel remove dawid25 General Mercedes-Benz 2 02-02-2010 03:05 AM
Door attenuator broken - what to do? fld W203 C-Class 3 01-14-2010 06:15 PM
Broken promise number ?? -Middle class taxes going up mlfun Off-Topic 151 07-30-2009 05:41 PM
