engine shut off and loss of power brakes - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-16-2010, 09:49 PM Thread Starter
Date registered: Mar 2009
Vehicle: 1994 S350D
I have an excellent condition (125k) S350D diesel 1994 model that has a hard time shutting off and now the brakes are loosing their power. I have brakes but have to push hard. Is this a vacuum pump and is it easy to replace? Any known threads and pics would be great. Want to do this myself....
rhoadrw is offline
post #2 of 5 (permalink) Old 04-17-2010, 12:18 AM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
The "power" of power brakes comes from engine vacuum and having that vacuum multiplied by the brake booster. So, you should be checking the vacuum line to the booster and then making sure the booster doesn't have a leak or fault.
MTI is offline
post #3 of 5 (permalink) Old 04-17-2010, 08:18 AM Thread Starter
Vehicle: 1994 S350D
thanks for the reply. If the engine is not shutting off properly would not that mean its the vacuum pump and not the brake booster? do i need a special vacuum gauge to test its vacuum? What should the psi be? By the way the engine shutoff and brakes work some times but its been getting progressively worse.
rhoadrw is offline
post #4 of 5 (permalink) Old 04-17-2010, 09:02 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
The car specific forum would know these issues better. But isn't it more likely a leak somewhere, an intermittent leak perhaps?
Diesel Benz is offline
post #5 of 5 (permalink) Old 04-17-2010, 09:08 AM
ollo's Avatar
Date registered: May 2009
Vehicle: S430 93K; E420 243K; 240D 242K
Quoted: 65 Post(s)
Problem may be a failed or failing check valve on the line to the power brake reservoir or the reservoir itself may be leaking.
ollo is offline
    Engine loss power eatorrijos W203 C-Class 2 07-25-2010 07:37 PM
    Loss of engine power and shushing on accelerating Jon Proffitt W163 M-Class 2 10-12-2008 02:35 AM
    Loss Of Engine Power - Help chrisw140 W140 S-Class 3 05-29-2007 10:22 PM
    Sudden loss of engine power John Peerce W202 C-Class 5 09-12-2005 12:09 PM
    Engine Power Loss gmurnane Vintage Mercedes-Benz 1 06-05-2005 09:25 PM
