1999 E300 turbodiesel fuel injector - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-15-2010, 06:42 PM Thread Starter
Date registered: Jun 2009
Does anyone know where I can purchase the socket/tool needed to remove the fuel injectors from a 1999 E300 turbodiesel. Also, when I remove the injector what should I be looking for to determine if its fouled. Is there a testing procedure????
mmlaw2002 is offline
post #2 of 2 (permalink) Old 04-15-2010, 08:31 PM
Kajtek1's Avatar
Vehicle: w211 E320 wagon 4M / Bluetec / Ford SD. Seeking affordable diesel pushmower
Quoted: 1044 Post(s)
I think you can order the special socket from a dealer. I manufactured one out of a steel pipe.
Testing injectors require special, high pressure pump. Not really DIY.
Depends on the mileage you might want to replace tips as a maintenance issue.
Your car belongs to W210 section, but this applies to all diesels, or at least the older ones with mechanical injectors.
If we annoy Ron (the adm) well enough, he will open diesel subforum here
Kajtek1 is online now
    1999 E300 turbodiesel MAF Question jhby@qis.net W210 E-Class 17 06-27-2016 08:29 AM
    1999 E300 Turbodiesel Rough Idle BRABUSD6 W210 E-Class 20 06-23-2013 06:19 PM
    1999 e300 turbodiesel owner jhby@qis.net General Mercedes-Benz 1 03-06-2010 11:50 AM
    what oil to be used in 1999 E300 turbodiesel 1999 E300 Turbodiesel W210 E-Class 5 11-05-2008 12:49 PM
    Question: 1999 e300 TurboDiesel, intercooler or not? waynelambright W210 E-Class 0 05-27-2008 01:41 PM
