Need some help with my W126. - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 04-15-2010, 04:44 PM Thread Starter
Date registered: Apr 2010
Hey guys, i'm new here. I just inherited a W126 sec amg from my grandfather, and I have a few questions.
First of all, I need more power from it. It is such a pimp looking car, it needs to be able to hold its own. What are some good sites, or am I stuck fabbing stuff?
Second, the engine overheated a little when I was pushing it really hard, so I cut a hole in the hood, and that seemed to help. Will the cut areas rust, or should I paint them? Do the relays burn out easily?
I am in the process of removing alot of the interior. I have stumbled upon alot of unecessary weight in the sound deadining, carpets, climate controls and seat motors. They sure did make theese heavy. I also have almost all the a/c ripped out, I did have to use a sawzall to get the lines thru the firewall out.
Basically the plans are to continue removing interior parts, cut off the mufflers/resenators and cat, and do a 3in side exit. I am also going to cut a few coils as this bitch sits waayyy too high, and needs to scrape. I haso have a blow thru turbo system in the works, but that will be a few months.
One thing I will say, is ever since I spraypainted it flat black (looks sooooo stellar) my grandmother has been acting weird.
Anyways, any help/pointers would be appreciated, along with any info you guys have on the car, as I pretty much no knothing about it. Thanks guys, take it easy on me, i'm a noob. Cheers
Thanks
W126 s-class amg (inherited)
stock for now
C126 is offline
post #2 of 9 (permalink) Old 04-17-2010, 06:59 AM
waybomb's Avatar
Date registered: Apr 2005
Vehicle: 2005 S55; 2003 ML350; 2002 C240; 1997 C280 Sport; 1991 300SL; 1986 190e 2.3 16V (2); 1968 W30 442
Quoted: 11 Post(s)
Go old school. Redo the top so ya got a diamond shaped rear window with a white vinyl roof. Get one of those flying Vee tv antennas. I think you can still buy those twin lit curb feeler setups at Warshaski in Chicago. Two for each wheel well. Need static straps with orange relectors, and mudgaurds with the naked chrome ladies on them.
Maybe some real wide-white-wall tires. Chrome wheels for sure. Very high offset - you want those wheels at least 6" outside the fenders for better cornering.
Then pull out all that useless benz powerplant and driveline stuff. Install a ricer 4 banger with four turbos so you can make 1500 hp at 17,000rpm and no torque at any rpm. Coupled with an Isuzu 3 speed, and you are pimpin.
Spark plugs in the exhaust ends and a windshield washer pump to pump gas in just before the sparks plugs. Man, will that be cool.
Thanks!
Fred
2005 S55
2003 ML350
2002 C240
1997 C280 Sport
1991 300SL
1968 W30 442
1988 46' Cougar US1 with Triple blown 572s
http://s4.photobucket.com/albums/y145/waybomb/
Warming the Globe, 24 Cylinders at a Time
Point me to a 126 wagon in the States PLEASE!
waybomb is offline
post #3 of 9 (permalink) Old 04-17-2010, 08:24 AM
Kajtek1's Avatar
Quoted: 1223 Post(s)
LOL.
Acting with chisel and sawzall will not gain you much popularity on this forum for MB lovers
I guess if you don't mind the noise -the sound dampening mats are not really necessary.
The bad news I have to give you -there is no easy way to increase power from those engines and your radiator will probably need replacement due to boiling stone build up. Do the radiator flush to start with and see how much it helps? Or cut another hole in the hood
You don't need the hood anyway. It is just extra weight.
Kajtek1 is offline
post #4 of 9 (permalink) Old 04-17-2010, 08:31 AM
50$84sd's Avatar
Date registered: Oct 2009
Vehicle: 1965 220se w111 *******1984 300sd w126 *******1991 350sd w126
This can't be real, he's got to be pulling our chain. Later.
50$84sd is offline
post #5 of 9 (permalink) Old 04-17-2010, 12:28 PM
waybomb's Avatar
Quoted: 11 Post(s)
Run without a hood - heat rises, right? Take the windshield and rear window out so all that air flows right through instead of all that horsepower to move the air out of the way.
Thanks!
Fred
2005 S55
2003 ML350
2002 C240
1997 C280 Sport
1991 300SL
1968 W30 442
waybomb is offline
post #6 of 9 (permalink) Old 04-18-2010, 11:36 AM
MRF
Date registered: Mar 2010
Vehicle: 1995 E320 Sportline sedan
I feel so bad for that poor car.
MRF is offline
post #7 of 9 (permalink) Old 04-19-2010, 04:15 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
Thanks
When I first read this I figured it was someone pulling an April's Fools joke a couple weeks late. "stellar"?????
Mike
Michael Pillay is offline
post #8 of 9 (permalink) Old 04-19-2010, 06:24 AM Thread Starter
Thanks guys for the...er... help. lol
The rad is fine, it was the engine bay cooling fan that I took out.
Since my first post, the car has gone a drastically different direction. I've swapped a diesel powerplant in (still benz), cranked up the boost and fuel pressure, removed restrictor plate and now it has some kind of balls. I've also stripped the entire interior of treim bits, carpet, cut half the dash board off, and welded in a full roll cage. The car now has a full 3in downpipe back side exit exhaust (exits just behind rear passenger door) I've already been to the track with it twice.
I do need to do something about the handling now though. Even with three coils cut off of each spring assembly, it handles like a low boat. I'm thinking of ordering some 8 inch, 500lb springs for all four, what do you guys think about that?
Oh a giant plus to the diesel powerplant is, with my side exit exhaust, I can completly cover a sidewalk (and pedestrians) in plumes of thick black smoke
thanks guys
stock for now
C126 is offline
post #9 of 9 (permalink) Old 04-19-2010, 10:41 AM
waybomb's Avatar
Quoted: 11 Post(s)
Handling - get those wheels I mentioned so they stick out at least 8" on each side - effectively making the car 16 or more inches wider! Use 280 compound slicks on all 4. Get rid of the springs altogether and run straight jack bolts.
Propane injection for that diesel - rig it up so you can use the windshield washer bought for the spark plug deal to suck up liquid from the bottom of an LPN tank and squirt it directly into the air side after the 27 psi turbo.
You'll have to modify the half shafts in back for all that extra torque - get some black pipe with the id the same as the od of the half shaft. Cut it down the middle and weld the halves to the half shaft. That should do it for ya.
Thanks!
Fred
2005 S55
2003 ML350
2002 C240
1997 C280 Sport
1991 300SL
1968 W30 442
waybomb is offline
    Generation 1: W126 European front bumper assembly + other W126 items Dr.Grillz For Sale/Wanted/Trade/Giveaway 7 12-24-2016 06:00 AM
    FS: New AMG DuckTail/3P spoiler (W126), NOS Wald Exhaust Muffler (W126), AMG Cluster Vlad_420SEC For Sale/Wanted/Trade/Giveaway 3 10-17-2009 01:13 AM
    w126 coupe lowering springs on a w126 sedan? PrinceGeorges The Discount Tire Direct Tire, Wheel, Brake & Suspension 4 08-03-2009 01:37 AM
    W126 Sedan/ W126 Coupe hood conversion reonalr W126 S,SE,SEC,SEL,SD,SDL Class 7 07-28-2009 12:08 PM
    History of the W126 (If you own a W126, READ THIS) SaleenS7 W126 S,SE,SEC,SEL,SD,SDL Class 8 01-22-2006 10:26 PM
