Fuel - Mercedes-Benz Forum
post #1 of 47 (permalink) Old 04-15-2010, 05:11 PM Thread Starter
Guest
Date registered: Apr 2009
Fuel
I have a 2006 ML350 and I wanted to know if I didn't use premium fuel, could it hurt the engine? I use the unleaded regular stuff, 87 octane I think.
Anyone know if it will make a big difference?
564462 is offline
post #2 of 47 (permalink) Old 04-15-2010, 06:35 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
All Mercedes-Benz gasoline fueled products REQUIRE premium. You cannot use lower grades of fuel, unless it is an emergency. You will destroy your catalytic converters burning 87, which will void your emissions warranty. You also lower your MPG, thus erasing any pump savings you think you may have achieved. If you are too cheap to purchase the correct grade gas, then you shouldn't drive a Mercedes Benz.
mr.xpowerseller is offline
post #3 of 47 (permalink) Old 04-15-2010, 06:44 PM Thread Starter
Guest
Ok, I was curious if it would make a difference hahaha. LOL, you're trying to tell me what I can and can not do over the internet? LOL, It's my car, and Ill do whatever I want with it. No need to get all defensive sounding.
The dealer never told us that we needed to have premium gas, so we didn't put it in. We get 22 MPGs in it anyway.
564462 is offline
post #4 of 47 (permalink) Old 04-15-2010, 06:51 PM
~BANNED~
I'm trying to tell you that it doesn't make any sense because you are actually spending more money then you are saving. Catalytic converters are not exactly cheap to buy. They cost $1060 for the right and $1070 for the left. There are two per ML. A grand total of $2130 plus installation billed at $135-150/hour. Seems like a giant waste of money to me, which can easily be saved by using the correct grade of gas. The word "required" is used only 100 times in the manual and then in big bold letters on the fuel door. I guess you missed that part.
post #5 of 47 (permalink) Old 04-15-2010, 09:43 PM
Kajtek1's Avatar
Quoted: 1197 Post(s)
Not that long ago government told some dealers to run the car on mixture of acid and sand.
They surprisingly run pretty long. .... relatively speaking
Kajtek1 is online now
post #6 of 47 (permalink) Old 04-16-2010, 05:26 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
This is one of the most often asked question on the forum. Do not be offended! You might save a little at the pump but you will have to pay when your cats go. Trust me on this. You will pay more in the end. I have had to change the cats on 2 different mercedes. Once I paid to have it done and it cost a pretty penny and once a buddy and I did it. Cost way less but it was a pain.
Like you said it is your car but if you are asking if there will be issues if you do not use premium- I would say most likely, yes.
Mike
Michael Pillay is offline
post #7 of 47 (permalink) Old 04-16-2010, 09:01 AM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 176 Post(s)
87 octane penalty
You will pay a penalty in performance. The knock sensor will prevent destructive engine knock but it does so by automatically retarding your ignition timing. This will result in slower acceleration and poorer fuel economy. There may also be a penalty in long term engine repair costs but I doubt anyone short of a bona-fide current Benz mechanic can tell us what that is despite what others say.
Look at it this way; at a $00.20 difference between regular and premium fuel, you are talking about an additional $4.00 for 20 gallons. If that diffence is worth it to you, by all means continue to use regular fuel.
rocky raccoon is offline
post #8 of 47 (permalink) Old 04-16-2010, 09:20 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Ah, but he gave you an owners manual. Can you read?
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #9 of 47 (permalink) Old 04-16-2010, 09:24 AM
Kajtek1's Avatar
Did the dealer also told you you can tow 40 foot travel trailer with your ML?
Look at it this way. You paid for 6 cylinder vehicle with life expectancy of 300k miles.
Running it on regular will make it performing like 4 cylinder and lasting probably below 200k.
Why didn't you buy KIA in the first place?
post #10 of 47 (permalink) Old 04-16-2010, 09:24 AM
H-TownBenzoboy's Avatar
Date registered: May 2003
Vehicle: 81' 300SD, 82' 300D
Quoted: 2 Post(s)
Hmm, why would a dealer tell you such a thing? Maybe because they'd like to make some money from servicing your ML because you damaged components by using regular gas?
1981 300SD DB881 ext./code #236 leather int. aka: thistle green ext./olive int.
1982 300D, DB877 ext./code #135 mb-tex int. aka: petrol green ext./creme int.
H-TownBenzoboy is offline
    Changed my fuel pump to fix my fuel gauge, and got an added BONUS. mikewired W163 M-Class 15 03-04-2012 09:52 AM
    Jumped fuel relay gets fuel to injectors!Still not starting! Distributor Plunger? salthepal W124 E,CE,D,TD Class 2 10-08-2008 04:24 PM
    long term fuel trim % with fuel pressure reg from pulley kit Subby_ R170 SLK-Class 5 05-06-2008 01:28 AM
    Suggestions on how to clean up fuel injector line threads in fuel distributor (380se) bcolins W126 S,SE,SEC,SEL,SD,SDL Class 3 04-25-2008 10:59 AM
    Update on Fuel Gauge Problem: Got Fuel Pump Replaced Today tjhsiao W163 M-Class 4 10-25-2002 05:47 PM
