Fuel - Page 5 - Mercedes-Benz Forum
post #41 of 47 (permalink) Old 05-03-2010, 09:06 PM
Date registered: Jun 2009
Vehicle: 1991 300E
Many popular myths about octane and the supposed ill-effects of running less than premium in a MB routinely resurface--killing catalytic converters, fouling injectors, destroying pistons, poor mileage and performance. Not happening. People are mostly repeating hearsay. Knowledgeable experts agree that lower octane will not damage a vehicle and that it is likely to have little impact on performance.
The biggest determinant of a fuel's impact on a vehicle is quality, and it should be noted that the detergent quality of a particular brand of fuels is likely to be identical across their product line. Bad tanks and low quality suppliers can, and have made, a big difference.
Below is the text of one of my previous postings on this, found here. It cites experts ranging from a well-regarded participant on this board to senior people at Mercedes, Porsche and the Society of Automotive Engineers. I believe it's worth reading, so I re-post.
One well regarded indy, Jonathan Hodgman of Blue Ridge Mercedes/AMG East (jhodg5ck on this forum), says: "IME, I have Never seen lower octane fuel hurt a cat." In fact, he uses 87 octane in his commuter wagon. His comments can be found here: Should I be running Premium fuel? (post #15)
Other experts seem similarly unconcerned about octane level. Below are some interesting quotes from "Why use premium gas when regular will do?," USA Today, July 30, 2003:
I personally use regular even though my owner's manual says you'll get better performance with premium," says Lewis Gibbs, consulting engineer and 45-year veteran at Chevron oil company. He's chairman of Technical Committee 7 on Fuels, part of the Society of Automotive Engineers (SAE) Fuels & Lubricants Council.
I go back and forth, and I'm hard-pressed to notice" whether there's regular or premium in the tank, says Jeff Jetter, principal chemist at Honda Research and Development Americas. He drives an Acura designed for premium.
Our cars must be able to drive all over the world, and so we are able to run on regular," says Jakob Neusser, director of powertrain development at Porsche's research and development center in Weissach, Germany. "You don't have to feel that a mechanical problem or anything else will happen" using regular gas, even in the highest-performance, regular-production Porsches.
That same article goes on to say that the quality of the fuel is the most important factor, not octane. Carbon build-ups and other issues can contribute to the demise of a catalytic converter, but not octane.
In "The Low-Down on High Octane Gasoline," the Federal Trade Commission notes:
As a rule, high octane gasoline does not outperform regular octane in preventing engine deposits from forming, in removing them, or in cleaning your car's engine. In fact, the U.S. Environmental Protection Agency requires that all octane grades of all brands of gasoline contain engine cleaning detergent additives to protect against the build-up of harmful levels of engine deposits during the expected life of your car.
From "Do You Really Need Premium ," Edmunds.com, August 20, 2007:
Until about 15 years ago, if a car called for premium gas and you pumped in regular, the car began to knock and ping and even vibrate. But that was before they essentially put a laptop under the hood of the automobile, said Dr. Loren Beard, senior manager of Environmental and Energy Planning, for Daimler Chrysler. Now, sensors take readings and tune the engine as you drive by adjusting the timing for whatever fuel you put in the tank.
The result is that a car that calls for the mid-grade gasoline will usually run on regular without knocking, Beard said.
Steve Mazor, principal auto engineer for the Auto Club of Southern California, said it is important to read the owner's manual carefully. The key is to figure out whether premium gasoline is "required" or "recommended." If it is recommended then a driver could opt to use a lower grade of gas, if they were willing to accept slightly reduced performance and fuel economy.
Volvo cars call for "premium fuel [91 octane or better] for optimum performance and fuel economy," said Wayne Baldwin, product/segment manager for the S60/S80. "However, there is absolutely nothing wrong with using 87 octane, as the knock sensors and engine management system 'protect' the engine from knocking."
Edmunds.com had a Volvo S40 in its fleet, so we consulted the owner's manual to see the exact phrasing in regard to fuel requirements. It said, "Volvo engines are designed for optimum performance on unleaded premium gasoline with an AKI (Anti Knock Index) of 91 or above. The minimum octane requirement is AKI 87." It appears that Volvo is making a recommendation for premium gas but is not requiring it.
The "Mercedes-Benz W124 (200, 200E, 230E, 260E, 300E, 230CE, 300CE, 260E4MATIC, 300E4MATIC) Owner's Manual," pdf download via mediafire.com, states: "For knock-free operation the engines have to be run on fuels which have the minimum octane ratings: . . . . Unleaded premium fuels 95 RON/88 MON minimum." In the United States, Canada and some other countries, the number on the pump is the average of the RON and the MON. In this case 91.5 octane would seem to be the factory requirement, depending on how you read it.
In "13 Must-Know Tricks to Max Out Your Road-Trip MPGs," Popularmechanics.com, author Mike Allen suggests:
Fill up with the fuel that has the recommended octane rating (let's assume it's 91) and drive for a few tankfuls. Check your fuel economy by dividing the miles driven by the amount of fuel consumed.
Now try a midgrade fuel and repeat. Make sure the driving route, traffic and weather conditions are similar. If the fuel economy is just about the same, try the next lower grade. Repeat until you see a drop-off in mpg. When you do, go back up one grade (to the one that didn't lower economy) for the best mileage.
Now, instead of dividing by the gallons consumed, divide by the cost of each tankful. This will give you the miles per dollar. If you are still saving money, reserve that better gas for times when you really need performance--like for towing.
I have followed this testing model in my own 1991 300E since buying it in June of last year, tracking the data in a spreadsheet. I logged over 40 tankfuls, well distributed between 93 and 89 octane, before even glancing at the results. Now with more than 60 tankfuls logged, still well distributed, I can say conclusively that I get 1-2 mpg better results with 89 octane than with 93 octane. Meanwhile engine temperature and oil consumption remain identical. This indicates that the engine is performing more efficiently with the lower octane fuel. And of course the fuel cost per mile is lower as well. I drive fairly hard, my mechanic friends tell me, and I have yet to hear a knock. Running 93 octane, I get about 320 miles per tankful. With 89 octane, I routinely get 340 miles a tankful or better. Recently, I got my first 400 mile tankful.
Most all of the user comments on octane I have seen on this forum have been opinions based on experience, usually second-hand and anecdotal. There are many horror stories passed along, failing catalytic converters, fuel injectors, clogged lines and more. However, in most of those stories the cause of failure is suspect or patently unrelated to octane. Few users are citing data and fewer still are acknowledged experts. As one poster to this thread says in his signature: "One anecdotal story does not constitute a statistic."
Note that all bolding and italics above is mine. Underlining indicates links to the sources cited.
Please excuse the length of this posting, but octane myths and flame wars are too common on this board. Users come here for accurate and helpful information on the operation and maintenance of their Mercedes. I feel that there is an obligation to call out postings that are inaccurate and not factually-based.
Pump what you like. Flame as you feel compelled.
300E91 is offline
post #42 of 47 (permalink) Old 05-03-2010, 09:18 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Originally Posted by mlrb2113 View Post
...Personally, I'll go to the 91 if I find the no- meth 89 that I can get lowers the mpg.
Maybe that was a typo but there is a big difference between methanol and ethanol. Actually only 1 vs 2 carbon atoms and a few hydrogens. CH4 (meth-) compared to C2H6 (eth-). Only a very few select cars with flexible fuel capability can deal with methanol.
It gripes me to no end that most of us can no longer buy 100% petroleum fuel. I refuse to believe ethanol-containing gasoline is somehow better for our cars. What it does, IMHO, is robs us of MPG and as mentioned mixes with the water/humidity in the air which further dilutes our gasoline.
Musikmann is offline
post #43 of 47 (permalink) Old 05-03-2010, 09:37 PM
Date registered: Apr 2010
Vehicle: '97 SL500, 06 Subaru Outback, LL Bean 3.0
It was a typo. Too much "meth" in our local fish wrapper (newspaper), I guess.
You're right about the ethanol. You used to put it in a gas tank so it would mix with the water and you could run it out ("Dri-Gas" or like that, if I remember right). Now it absorbs its own water from the atmosphere.
My friendly neighborhood guy sells the 100% gas and a Kroger's used to, too. Maybe still does. I don't know how the very few get it and nobody else does.
Fortunately, it's easy (and fun) to check.
mlrb2113 is offline
post #44 of 47 (permalink) Old 05-03-2010, 09:42 PM
When they used lead in gas, the higher the octane the more lead deposits you got. Don't know if the stuff they use now leaves deposits or not.
mlrb2113 is offline
post #45 of 47 (permalink) Old 05-03-2010, 09:51 PM
Musikmann's Avatar
Quoted: 6 Post(s)
LOL, good joke.
I don't think so. I had a fuel line freeze-up once and started using Dri-Gas. Somewhat later I checked the ingredients and at least one of them was methanol.
I have used Chevron for years largely because they never added ethanol. Just recently, my local station owner told me the "government" forced all stations in our area to add it. Now Chevron/Texaco is pulling out of about 13 states entierly (incuding mine), but the good news is Shell (Top Tier fuel) is replacing at least one of them.
post #46 of 47 (permalink) Old 05-03-2010, 09:58 PM
Musikmann's Avatar
Quoted: 6 Post(s)
That's the very reason we should all be using the Top Tier Fuels. Only 2 are readily available here, Chevron and Shell. Texaco is one too but the nearest is 30 miles away. Google TTF and you might have others in your area, like Conoco, Phillps 66 or 76. Plus there are a few others.
post #47 of 47 (permalink) Old 05-04-2010, 10:14 AM
[QUOTE=Musikmann;4129119]LOL, good joke.
<<I don't think so. I had a fuel line freeze-up once and started using Dri-Gas. Somewhat later I checked the ingredients and at least one of them was methanol.>>
Ethanol & methanol both absorb water similarly; maybe all alcohols do. I carry a small bottle of isopropyl alcohol trout fishing to make my dry flies dry faster when they won't float anymore.
<<I have used Chevron for years largely because they never added ethanol. Just recently, my local station owner told me the "government" forced all stations in our area to add it. Now Chevron/Texaco is pulling out of about 13 states entierly (incuding mine), but the good news is Shell (Top Tier fuel) is replacing at least one of them.>>
Almost every station here adds ethanol. There was 1 Weigles that didn't, but the rest do. Also, there was at least 1 Kroger's that advertised that it didn't; don't know about the others. I checked Shell & Exxon gas just to see if my test method worked easily showed their alcohol, and it did. I'm lucky - my mom & pop station is only a few blocks away, but it only sells 87 & 89, and it's more expensive than the others. I had to tell the owner to advertise "100% Gasoline" and he did and said it really helped sales.
I think there's some state or federal incentives to adding ethanol; maybe to the distributor which may be why my station's more expensive.
mlrb2113 is offline
    Changed my fuel pump to fix my fuel gauge, and got an added BONUS. mikewired W163 M-Class 15 03-04-2012 09:52 AM
    Jumped fuel relay gets fuel to injectors!Still not starting! Distributor Plunger? salthepal W124 E,CE,D,TD Class 2 10-08-2008 04:24 PM
    long term fuel trim % with fuel pressure reg from pulley kit Subby_ R170 SLK-Class 5 05-06-2008 01:28 AM
    Suggestions on how to clean up fuel injector line threads in fuel distributor (380se) bcolins W126 S,SE,SEC,SEL,SD,SDL Class 3 04-25-2008 10:59 AM
    Update on Fuel Gauge Problem: Got Fuel Pump Replaced Today tjhsiao W163 M-Class 4 10-25-2002 05:47 PM
