99 c280 Front Windows/Mirrors Do Not Work - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 04-15-2010, 09:04 AM Thread Starter
Date registered: Mar 2010
Hi, my front mirrors and windows do not operate. My rear windows work fine. I replaced the window switch and still have the same problem. I just read in another thread that this could be due to water in the door causing a relay to trip. Generally, if i disconnect the battery, the windows will work again..or at least untill it rains??
Any advice would be greatly appreciated..or how to prevent water gaining access to my door?
-Joe
Joey Benz is offline
post #2 of 10 (permalink) Old 05-21-2010, 12:01 PM
Date registered: May 2010
Vehicle: 1998 E 320, 131.000 miles
mercedes 99 c280-all power windows and mirrors not working
Hey I was wondering if you ever found a solution to the problem..I am having the exact same problem on my car, none of the power windows mirrors or trunk release switch work,BUT when I disconnect the battery for 3 seconds they all work just fine for about 15 minutes...I checked the fuses in front in trunk and the relays out in the front they all are fine....
ANY suggestion would be appreciated..its driving me nuts!
Thanks
-----------------------------UPDATE:::
For window problems on a mercedes c220-230-280-1994-2000 year.....p.s. mine was a 99 c280.
For all of you people having problems with windows...not working in the front or back..mirrors and airbag sign doesnt come on at the Window switch assembly by the gear knob...THEN you most like have the problem with the window switch assembly!!!!Before you buy a used one from ebay or local junk yard DO THIS:
around the gear shift there is a square plastic, take it out, take the whole window switch assembly OUT..it should all come out ...there is 2 plugs in the back of it...plug them off...
With the ignition on...put the plugs back on..and try the windows if they work..if they do it is the switch assembly faulty..just get another one
I would assume that you have checked the fuses under the hood...and in the trunk before..
Also another way is to take out the battery for a minute and plug it back on..i used to do that and switches would work fine for 20 minutes or so..than id have to take the battery out again or the plug on the switch assembly.
On the alldata...there was a note from mercedes that there is big problem with water entering through the back doors...so they advised sometimes to check the door modules..to make sure there isnt any corrosion ..and if there is signs of water in it sometimes just pluggin it off might let the other windows work ...
I hope this helps!!good luck!
wolfb7 is offline
post #3 of 10 (permalink) Old 11-30-2010, 06:35 PM
Date registered: Nov 2010
We had an unfortunate spill this weekend into the console of my '99 E300TD and had the same symptoms of windows, mirrors, and trunk release not working. However, the switches do eliminate with the headlights on, and the antilock break switch at the top also works (separate connector and on the dry end of the spill).
I tried the trick of disconnecting the switch, turning on the ignition switch, and then replugging the connectors with no response - both with the car started and the ignition on only - no difference.
I have a can of electronics spray that I will use to attempt cleaning out the switches and connectors but believe I will come up empty handed and need to buy the used switch on Ebay for $130.
Any other recommendations ...
Tom Phillip (concordian) 262.391.4476
concordian is offline
post #4 of 10 (permalink) Old 12-02-2010, 07:02 PM
hey man, sorry for the late response. i would certainly try cleaning it and letting it dry for a good 20 minutes. Also I know that there is a relay that controls it, but on mine it wasn't that the problem.
If that doesnt work i'd say to get a used one from the local junkyard or ebay. I paid 80$ for mine and it solved the problem.
wolfb7 is offline
post #5 of 10 (permalink) Old 12-03-2010, 02:56 PM
I ended up purchasing the used unit on Ebay after the 3 fuse boxes all checked out. I expect the new switch will do the trick.
God's blessings ...
Tom Phillip
post #6 of 10 (permalink) Old 02-06-2011, 03:36 PM
Date registered: Feb 2011
Vehicle: C280, 1999
God's blessings ...
Tom Phillip
Did you have a favorable result with the replacement window switch assemble? Or, was it something else? THX
I've a C280, 1999, the passenger side rear window doesn't operate. I pulled the assemble from the shift console, did the replug and it still refused to work. I'm wondering how to further diagnose the one window failure. Also, I'm doing the ECU reset every day to make the other windows and the mirrors work...
oregon321 is offline
post #7 of 10 (permalink) Old 02-06-2011, 04:20 PM
Hey im not sure for only one window, but if you have to reset the main switch or ecu in order for it to operate the mirrors and the windows i'd go with the main switch assembly... or you can try plugging out the window that is not working and see if the mirrors and the other windows will work..in that case Id suggest that the actual module of the one not working window is the problem.
Good luck!
wolfb7 is offline
post #8 of 10 (permalink) Old 02-07-2011, 07:50 AM
The used module did the trick for me! be careful that the switch layout is the same as yours ... the bezel was wrong but the number of switches and their layout was the same and worked just fine for me.
post #9 of 10 (permalink) Old 02-07-2011, 07:04 PM
Vehicle: C280, 1999
Good luck!
Thank you kindly for your response.
I'm searching for a replacement main switch assembly. New is $350+. Do you have any good hunting spots for me?
I wonder how I would unplug the bad window? I thought that I could pull the switch for it from the assemble but it is part of a circuit board. I suppose that I could open the back door panel and unplug it there. Is there an easy way to uplug the one window?
post #10 of 10 (permalink) Old 02-07-2011, 07:14 PM
Vehicle: C280, 1999
Congratulations, you are a success! Way to go. Love it. And you are encouraging me.
I'm not finding much on ebay. What key words did you use to search? Something like this, "mercedes main swith assembly."
Thank you for your help.
A few pics of my, 1999 C280, window switch assembly for your amusement:
Top:
Bottom:
Wire connection:
    1998 C280 front windows/mirrors stopped working froggy67 W202 C-Class 6 09-08-2009 10:50 AM
    no front power windows, seats, mirrors jjohnv W210 E-Class 13 12-02-2008 10:36 PM
    my mirrors, locks, and windows dont work!! newb1e W163 M-Class 9 11-21-2008 06:48 AM
    03 ml 350 windows, locks, mirrors, dont work newb1e Audio & Telematics Forum 0 11-20-2008 01:33 PM
    front windows, mirrors and alarm gchild W202 C-Class 2 04-02-2007 03:00 PM
