Clk dead battery problems, Accelerator - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-12-2010, 12:36 PM Thread Starter
Date registered: Apr 2010
Angry Clk dead battery problems, Accelerator
Hello to you all..........I have a problem with my clk 200 the battery went dead for about 3 weeks(was away on hols) came back and jumped stated it but had very little petrol in the thank in reserve.... so it cut out. Put in petrol and jumped again and it started,thought it was job done but this was just the start of my probs....... had to find the code for the radio and enter it , the windows would go down but could not get back up for about an hour, then and this is the MAIN PROBLEM. The car will not rev passed 2000 and then revs drop low and when i push the accelerator there is now power at all even when floored, even when left idle revs are droppin and going up also there is a lot of smoke coming from exhaust..........any help will be greatly appreciated of course. Cheers.
gerryspades is offline
post #2 of 2 (permalink) Old 04-12-2010, 12:57 PM
hi,
Not sure without seeing the engine computer on a computer,but it sounds like you have lost your programming in the engine computer(ecu),the reason it runs like it does is because it's in limp home mode,I hope this fixes it for you,since the battery was dead it would be a high probability that is the problem.......Battery should have stayed up too,unless something is drawing power....Good luck!
c230FiXer2 is offline
    Dead Battery: roof and command problems?! dsb R171 SLK-Class 38 12-12-2013 06:35 AM
    CLK 55 Dead battery focus on this 1 C209/A209 CLK-Class 2 02-12-2010 02:39 PM
    05 clk 500 dead battery car wont unlock wheelred12 C209/A209 CLK-Class 3 05-04-2009 05:59 PM
    Dead battery, radio problems entering code, help! luminox G-Class 15 10-20-2007 09:28 AM
    Dead Battery could cause more problems than u think Ron G C209/A209 CLK-Class 6 09-30-2006 12:42 PM
