'Clunk' in drivers seat back - repair - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-12-2010, 05:32 AM Thread Starter
Date registered: Feb 2006
Vehicle: 2001-W210-CAPRI METALIC BLUE-/ 2002-W210 E300D
Location: Los Angeles, Ca, Aberdeen Scotland, Lawrence Ks.
Cool 'Clunk' in drivers seat back - repair
Hello Forum;
As the drivers seat back is moved forward and back and I was getting a loud 'Clunk' sound and the seat memory feature was never just right in any position. I tried several fixes but ended up taking the seat appart.
Estmates for repair ran from 300 to 1500 US$
- I took the seat out of the car by removing the bolts and caps....1
- removed the wires .... 3
- removed the 2 trox screws and the seat back cover ....4
- snaped off the side plastic cover ....5
- snaped out the night light ....6
- gently pushed up on the leather and un hooked it....8
- removed the 2 torx bolts on the side releasing the seat back motor ....12
- reached in and remover the motor assembly....14
- pushed UP on the wire connector....16
- gently opend the 3 snap clips ....18
- lifted out the drive gear ....20
- replaced the drive gear with the broken off tooth....24
ther appears to be no limit on this motor and if put all the way down on the back seat the motor ca strip a gear.
Hope this helps.
B
ID:	301821   Click image for larger version
ID:	301822   Click image for larger version
ID:	301823   Click image for larger version
ID:	301824   Click image for larger version
ID:	301826   Click image for larger version
ID:	301827   Click image for larger version
ID:	301828   Click image for larger version
ID:	301829   Click image for larger version
The finest example of automobile engineering in the world
Floats like a CADI
Stings like a BMR
Stingy as a Prius
and.... all Mercedes Benz.
MRBSMITH is offline
post #2 of 2 (permalink) Old 04-12-2010, 05:35 AM Thread Starter
Cool more pics
Final set of pics.
The same seat mechanics are used in many late model MB.
B
ID:	301831   Click image for larger version
ID:	301832   Click image for larger version
ID:	301833   Click image for larger version
Floats like a CADI
Stings like a BMR
Stingy as a Prius
MRBSMITH is offline
    Rear seat back: re-dye or repair? slandsecdriver W126 S,SE,SEC,SEL,SD,SDL Class 3 10-24-2009 08:40 AM
    drivers seat won't move forward or back Wien21 W203 C-Class 7 12-03-2008 03:29 PM
    Seat back repair through 1982 model Gregs300CD W123 E,CE,D,CD,TD,TE Class 2 05-16-2007 06:57 PM
    Ouch! How to fix spring poking in drivers seat back? MustMakeAmends W124 E,CE,D,TD Class 4 08-27-2005 01:30 PM
    Back-Seat Drivers wanted Tech-Tune R129 SL-Class 15 05-16-2005 07:05 AM
