2002 E 320 Trans Slips to Nuetral - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 04-11-2010, 08:34 PM Thread Starter
MyMBE320's Avatar
Date registered: Apr 2010
Vehicle: 2002 E320 1993 Mustang 2003 VictoryV92
Send a message via Yahoo to MyMBE320
Hi everyone. I just bought a 02 E 320. It has always been serviced at a Benz Dealer. However, I have recently had an issue where the transmission will sometimes go to neutral and the engine revs up. Sometimes I have to put it into neutral manually then back to drive. The trans has the auto stick type of trans. I also see that there is no way to check the fluid level. Does anyone have any ideas? I heard that it could be anything from a trans speed sensor to low fluuid and worse yet the wrong type of fluid.... I don't know.....
MyMBE320 is offline
post #2 of 2 (permalink) Old 04-11-2010, 09:14 PM
Kajtek1's Avatar
Quoted: 1070 Post(s)
Welcome to the forum. Your car is W210 body and we do have very well informed bunch of W210 owners on this forum. Go to the W210 section and start with stickies on the top of the pages. Out there you will find the transmission dipstick scale and advise how to check the level with steel cable, or plastic tubing.
Also the moderator there is very good in transmissions troubleshooting, so you won't stick long without an advise.
Kajtek1 is online now
    Trans Fluid Change on 1998 E-320 Paul Mellerowicz W210 E-Class 8 09-03-2007 06:03 PM
    2002 C230 value with bad trans dreamer98513 W202 C-Class 1 09-03-2007 01:41 PM
    300TE 4Matic trans slips and doesnt shift RidiculousYJ W124 E,CE,D,TD Class 0 08-10-2005 11:35 AM
    00 ML 320 Non shifting trans? Kerr W163 M-Class 6 01-06-2005 06:53 AM
    99 CLK 320 TRANS IS MESSED UP! HELP :( Anthony C208/A208 CLK-Class 3 03-08-2002 08:21 PM
