gear change and revs gone mad help - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-10-2010, 05:20 AM Thread Starter
Date registered: Sep 2004
Vehicle: SL320'99WDB1290642F1776727M11294330333401GB7226/190E'90W2010242F733620M10296222140437GB7224
Quoted: 48 Post(s)
Question gear change and revs gone mad help
gear shift revs gone mad help
I hadn't driven my car for 6 days - put the accelerator to engage kick-down to over-take a truck and the car jolted violently like something was stopping it accelerating through the gears- the rev counter worked ok when driving around 40 but seemed to want to stay at 2000rpm and if i pushed the revs to 2500rpm it would jolt violently. Then in P it revs to a limit of 4000rpm and cuts out consistently when it should go to the red when it hits 6000rpm and cut out. So maybe it is not a gear change issue- or maybe something is being denied to the gearbox and then it jolts into position-maybe some electrical message is not getting to the gear box or is the car being denied air at the right time???????????
Any chance of some ideas as it will be a while before i can get my mechanic to look at it-
I now don't trust my car to pass a truck without endangering me but i will persevere
this car has been very well taken care of throughout its 89000 miles
i have a constant rough idle when stationary and sporadic puffs of white smoke (running lean) which i can't source in case that has relevance
work done -
gear box rebuilt fully and properly
plugs htleads fuel filter air filters oil oil filter MAF crank position sensor throttle body cleaned valve cover gaskets
Thank you for any ideas
regards
darragh
darraghodonnell is offline
post #2 of 4 (permalink) Old 04-10-2010, 07:57 AM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
If it were a V-8 version, I'd say it was a crank position sensor. I don't know the 6 cylinder versions well enough to say that with confidence. The rough idle may indicate MAF troubles either as well or as the sole cause of the problems. I'd suggest you take it to a place that can read the codes from the OBD II port. Perhaps that will tell you exactly what the problem is.
Sorry I can't be more confident or specific.
Cheers.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
post #3 of 4 (permalink) Old 04-10-2010, 08:45 PM Thread Starter
Quoted: 48 Post(s)
thank you drJ-
new cps and MAF recently
i'll just have to wait for my mechanic to read codes
if you think of anything else let me know
regards
darragh
post #4 of 4 (permalink) Old 04-12-2010, 04:26 PM Thread Starter
Quoted: 48 Post(s)
No codes were thrown by the star machine today- my mechanic will look at it wednesday again and i'll get back, thanks,
Darragh
    gear shift revs gone mad help darraghodonnell R129 SL-Class 4 04-13-2010 08:53 PM
    Engine revs up in 1st gear Electra7 W210 E-Class 3 12-08-2009 12:16 PM
    M104 engine revs fine except when in gear kboutorabi W124 E,CE,D,TD Class 2 07-22-2007 09:14 PM
    1st gear revs high Panther201 W201 190-Class 3 03-29-2006 06:17 PM
    High revs for 1st gear when engine cold redzer007 W124 E,CE,D,TD Class 3 12-07-2004 01:39 PM
