Has anyone lowered their car? Please help! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-09-2010, 11:19 AM Thread Starter
Date registered: Jan 2010
Vehicle: 2000 CLK430 (W208)
I have a 2000 clk430 - 208. Everything is stock, except for the larger wheels I just got. They're 19x8.5 in the front, and 19x9.5 in the rear. I put them on, and as expected, it's sitting pretty high. I want to lower it now, but admit I don't know much about it. Has anyone lowered their car on similar size wheels? From reading different posts, I get the impression that buying H&R or Eibach springs to bring it down 1.2-1.4", along with sport shocks, would work ok. My other questions are that people say to get a camber kit at the same time to avoid uneven tire wear. I've also read that you can use a camber kit in the rear only, and just camber bolts in the front. Has anyone done this, and are the bolts something aftermarket, or from the dealer? Do I need to go anywhere special to have all that installed, or will most mechanics know how to set it all up? And last, I read on here about changing the spring pads. Is that something I should do too? ...is it difficult for me to do, or should it be done when the other changes are made?
-To anyone who read all of that, I really appreciate it, along with any help on the subject. Thank you in advance.
juliusseizure is offline
post #2 of 3 (permalink) Old 04-09-2010, 01:46 PM
Chicky's Avatar
Date registered: Apr 2007
Vehicle: 1991 R129 500SL
Quoted: 50 Post(s)
Hello juliusseizure,
I hope that the staggered wheels that you've installed, are W208 specific, with regards to offset, as I run the same sizes on my SL fitted with specific offet AMG rims. I also have the H&R + bilsteins + #1 spring pads, and I plan to install, in the future. camber correstion front and rear kits. I am not versed with your front suspension setup, but you may check the W208 subforum here, with regards to just the use of bolts for your front camber correstion. I plan to use the "RDM" brand of camber correction kits, if interested, you may just google it, as I have to look for where I saved the link. You also should have your fender lips rolled, you can search for data on the MB WIS, specific to your W208, under "fitting of AMG wheels", it has the diagrams and instructions.
Hope this helps
Chicky is offline
post #3 of 3 (permalink) Old 04-09-2010, 02:15 PM Thread Starter
thank you
Thank you so much. I will look into those items, and check the W208 section here. I really appreciate the time and help.
    Where in LA can I have my car lowered? Cabbe C215 CL-Class 1 03-20-2009 11:20 PM
    Lowered the car Geovannie C208/A208 CLK-Class 11 01-21-2007 02:38 PM
    lowered my car but... di_nate W210 E-Class 22 11-22-2006 09:18 PM
    got my car lowered rk3685 C208/A208 CLK-Class 13 09-12-2006 03:04 PM
    My car lowered dinkoslk R171 SLK-Class 13 02-08-2006 10:59 AM
