'94 C220 Idle Problem? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-08-2010, 10:15 AM Thread Starter
Date registered: Oct 2009
I have a '94 C220. The past year or so, it idles really low (especially when the A/C is used!). Took it in, the mechanic said it was the typical bad wire harness- however, enough posts on here indicate that may not always be the issue, so I didn't want to shell out the $ on the unknown.
However, yesterday when I was at a stoplight, the RPMs surged and wouldn't let down. It was all I could do to mash on the brake and not hit the person in front of me. I shut the car off, and turned it back on. Immediately, it surged to at least 4000 rpm.
Does this car use an idle control valve, or idle computer-type unit? If I can find a used one locally, I wanted to try that first. I can't seem to find anything (parts, advice, etc) related to the idle on my car anywhere online!
reent612 is offline
post #2 of 5 (permalink) Old 04-08-2010, 10:23 AM
jhodg5ck's Avatar
Date registered: Sep 2002
Vehicle: Depends on the day!
Quoted: 14 Post(s)
Send a message via AIM to jhodg5ck
Have you inspected the harness?? Only takes a minute to cut open some insulation to have a look.
How many miles on your C?
Jonathan
Blue Ridge Mercedes/AMG East
Jonathan Hodgman
http://www.blueridgemb.com/
Enthusiast Service, Restoration & Tuning.
Authorized RENNtech Dealer & Installer
Follow Us on Facebook!
Located in the Atlanta area
87 Hammer Wagon 6.0L 32V
87 Hammer 6.0L 32V
86 560SEL AMG 6.0 32V
etc....
Mercedes Repair Atlanta
jhodg5ck is offline
post #3 of 5 (permalink) Old 04-08-2010, 10:28 AM Thread Starter
I've got about 140K on it.
I haven't cut open any of the harness- the general consensus here seemed to be that it was a nit-picky thing that could short out if the insulation were bad. A mechanic showed me a split in the insulation in one area. Incredibly small, but there was a tiny crack in it.
reent612 is offline
post #4 of 5 (permalink) Old 04-08-2010, 11:04 AM
jhodg5ck's Avatar
Quoted: 14 Post(s)
Have to disagree, if you have a 92-95 Merc that's behaving oddly the First thing you do is replace the harness.. They All go bad. You're lucky to have made it this far IME.
With wonky wiring you just end up chasing ghosts....frustrating and costly!
Jonathan
Jonathan Hodgman
87 Hammer 6.0L 32V
etc....
jhodg5ck is offline
post #5 of 5 (permalink) Old 04-08-2010, 11:29 AM Thread Starter
Definitely agree...thanks for the thoughts!
My mechanic recommended replacing the idle computer (or something like that) after replacing the harness, so a bad harness didn't short it out. Does that sound about right?
I wasn't sure about the idle control computer...there seem to be 2 ECM-type things, I'm guessing one of those is for idle control?
reent612 is offline
    Feedback on C220/C250 on idle VicB7 W204 C-Class 0 09-18-2009 06:59 AM
    1994 C220 Will Not Idle stevepinkerton W202 C-Class 2 12-26-2008 03:34 PM
    Rough Idle 94 C220 jpowell490 W202 C-Class 4 04-01-2008 01:33 PM
    c220 idle adjustment Chief General Mercedes-Benz 0 10-26-2005 03:05 PM
    1995 C220 idle stuck jkane W202 C-Class 0 05-18-2004 02:20 PM
