98 ml320 ac cooling fans not working - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-06-2010, 05:11 PM Thread Starter
Date registered: Dec 2009
my ac fans do not work , I replaced the pressure switch with no luck also unpluging the pressure switch is the only way my ac will come on. I checked the relay and the fuse and both are good . I put a test light on the 4 wires going to the fan and noticed that all 4 go to ground . Any help would be great .
jeepman is offline
post #2 of 3 (permalink) Old 04-09-2010, 02:22 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Can you clarify about "all four go to ground"?
flyboyike is offline
post #3 of 3 (permalink) Old 04-09-2010, 03:59 AM Thread Starter
I took a test light and hooked to the positive side of the battery and when I probed the four wires all four lit the test light . My intentions were to determine what two wires were the ground wires. The test light was bright , not a dim glow.
jeepman is offline
cooling fans DORIAN R129 SL-Class 3 05-02-2009 01:19 PM
Cooling Fans Always On md500 W124 E,CE,D,TD Class 12 12-03-2006 04:54 PM
Center two AC/heater fans not working while two fans on the sides are OK bespokeonly R129 SL-Class 4 11-05-2005 04:00 PM
Cooling Fans toslk R129 SL-Class 2 06-28-2004 04:08 PM
Cooling Fans: Why do they come on so often??? Darkmann W163 M-Class 11 07-22-2002 05:23 PM
