Rear Cargo (Quarter) window seals - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-02-2010, 04:17 PM Thread Starter
Date registered: Mar 2010
Post Rear Cargo (Quarter) window seals
Hi folks, I have a 1992 Mercedes 300TE Wagon. Both the right and left side quarter windows (cargo area) are leaking slightly. I have removed the driver side, cleaned the opening, the window, and the trim. The seal looks pretty good but I'd prefer to replace to make sure I'm getting a tight seal. I have read that sealant/caulking is not necessary. Is this correct? The opening themselves are in pretty good condition, only two small areas of rust that I have corrected (cleaned, evapo rust, and painted with rustoleum). Thanks for any help.
Greg
greglynnm is offline
post #2 of 3 (permalink) Old 04-08-2010, 12:41 PM
Date registered: Jun 2007
Vehicle: 1995 E320 Wagon
While I don't have an answer to how to put the window back in, I do have a question: How do you remove these windows? I have a 95 E320 and the rear windows leak a little. I see references to cleaning and, perhaps, replacing the seals, but I have no idea how to get the window out in the first place without breaking it. Can you share any tips?
pbeamtn is offline
post #3 of 3 (permalink) Old 04-11-2010, 09:50 AM
Date registered: Jun 2009
Vehicle: 1991 300E
300E91 is offline
    replacing rear vent/quarter window W126fahrer W126 S,SE,SEC,SEL,SD,SDL Class 13 03-03-2009 01:55 PM
    Leaky Driver's Side Rear Quarter Window TheJimbo R170 SLK-Class 0 05-17-2006 06:45 PM
    Rear Quarter Window Inop Sgooter R170 SLK-Class 5 08-03-2005 05:23 PM
    Has anyone every had the rear quarter window ... Jacques R170 SLK-Class 5 08-17-2003 04:13 PM
    Leaving rear quarter window down with top up... DanPro (Montréal) R170 SLK-Class 2 05-06-2002 09:41 AM
