HELP -SOON TO BE EMERGENCY - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-27-2010, 07:09 PM Thread Starter
zyggiest's Avatar
Date registered: Nov 2007
Vehicle: 99 E320 4matic, 05 Saab 9-3, 96 Landrover Disco, 72 Porsche RSR clone project, 74 Dodge D10
Not to be melodramatic but I have 1.5 hours to figure out how to get my windows up before a thunderstorm arrives and no garage.
car - 99 e320 4matic
I disconnected my battery today to treat a little rust where acid had gotten on it, afterwards i reinstsalled my battery and my windows which were all in the lowest position will not go up. I tried resynchronizing, I can hear the window motors make a sound when I try to raise or push the lower position, but they do not move.
My battery is fine but I hooked a charger to it just in case it had discharged a bit- I am turning the key to the acc position and holding the windows for as long as a minute in both the up and down positions -no movement
is there an override?
about to start removing panels to try manual push up
"Professional advice is welcome, amateur advice appreciated, swags respected"
zyggiest is offline
post #2 of 6 (permalink) Old 03-27-2010, 07:23 PM Thread Starter
zyggiest's Avatar
Add'l info
Could I have hit something around the fuses where the battery goes that would stop the windows from going up - sort of reaching but I don't get it. I don't have a repair manual.
I can hear each motor when I try them - they just dont go up and down
If it matters the seats and sunroof work.
zyggiest is offline
post #3 of 6 (permalink) Old 03-27-2010, 07:31 PM Thread Starter
zyggiest's Avatar
STill Trying
Hooked up ODB meter - no codes
zyggiest is offline
post #4 of 6 (permalink) Old 03-27-2010, 07:41 PM
Triggerhappy's Avatar
Date registered: Nov 2009
Vehicle: 1978 240D
Quoted: 41 Post(s)
Triggerhappy is offline
post #5 of 6 (permalink) Old 03-27-2010, 07:46 PM Thread Starter
zyggiest's Avatar
Problem Solved
I guess I'm so used to pushing the windows all the way in the up and down position till the switch "clicks" I was trying over and over to put it into "express position and nothing was happening. So I went real easy and just rocked the switch without pushing it all the way and the windows went up one by one. Then I re-synced them now that I could make them go up and down. It took a few trys and more like 15 secs to hold them in both the up and down position but its all good now.
Hope this helps someone else.
zyggiest is offline
post #6 of 6 (permalink) Old 03-28-2010, 08:45 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Thanks for the tip. For future reference you have a W210 and we have a forum (in sedans section) devoted to these.
Musikmann is offline
EMERGENCY!! 911 EMERGENCY!!! doin12volt W202 C-Class 4 12-22-2008 11:39 PM
emergency! need help please! jayzo Audio & Telematics Forum 1 12-27-2007 12:33 AM
NEED HELP!!! EMERGENCY delmedina W124 E,CE,D,TD Class 6 11-30-2005 12:14 AM
EMERGENCY: WHAT DID I DO? zaystev W126 S,SE,SEC,SEL,SD,SDL Class 2 10-03-2003 01:57 PM
New Emergency Triangle for ML320/350/500 equipped with an (empty) Emergency Triangle Compartment S4toML W163 M-Class 4 01-16-2003 07:57 PM
