oil level low, then check engine light comes on - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-25-2010, 07:42 AM Thread Starter
Date registered: Jan 2010
Smile oil level low, then check engine light comes on
Hi,
I need help with oil level light coming on and then right after that check engine, stop engine light comes on in red. When i go to turn off the car it read malfunction 1.
The car runs great, but will not pass inspection with this message coming up on dash. HELP
I have a 2000 s430, 108 thousand miles. Oil changed 3 months ago. When i took it to the dealer i told him that the light was coming on and he said after the oil change the mechanis said light was still coming on but i chould just drive it for a few days and it should go away. Well it hasn't and when i called dealer they said i have to bring in again for diag. testing and another $250.00!!!
kathydal is offline
post #2 of 3 (permalink) Old 03-25-2010, 08:23 AM
Kajtek1's Avatar
Quoted: 1223 Post(s)
Get the $39 OBDII scanner and save $210 on the spot.
I assume you confirmed with dipstick the oil level is OK?
Welcome to the forum.
Kajtek1 is offline
post #3 of 3 (permalink) Old 03-26-2010, 12:00 PM
Musikmann's Avatar
Quoted: 6 Post(s)
You have a W220 and there is a forum for those. That might be something inherent to the early models so I would check there. IMO that dealer should have done the diagnostics the first time you had it there due to the check engine light. To the best of my knowledge, dirty or low oil will not trip one of those so it has to be something else.
Is the low oil light followed by the CEL happening just like it was before the oil change?
Musikmann is offline
    oil level low, then check engine light comes on kathydal General Mercedes-Benz 0 03-25-2010 07:35 AM
    Engine Oil Level Low MBs600v121998 W140 S-Class 8 02-03-2010 09:09 PM
    When the Low Oil Level light comes on jwrape General Mercedes-Benz 8 12-20-2008 04:04 PM
    Low oil light on but oil level is correct bavenda W163 M-Class 4 05-22-2007 08:48 PM
    low oil level light 98_ml320 W163 M-Class 8 01-17-2006 08:57 PM
