SLK 230 1999 ENGINE LIGHT CODE NEED HELP! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-24-2010, 04:09 PM Thread Starter
Date registered: Mar 2010
Post SLK 230 1999 ENGINE LIGHT CODE NEED HELP!
My slk engine light on code show P0170 and P1420, I brought my car to a local mechanic clean out MAF, changed air filter, check for vacuum leak, changed rubber tube, changed catalyic converter due to faulty smell underneath the car "problem solved", but engine light still there I brought it to local Mercedes for a diagnostic show 2 pages of problem that need to be fix most of it are minor, does anyone have similar problem ? how to get rid of the engine light so I can pass the inspection emission, I just unplugged MAF drive it around hopefully engine light will not go back on, help me out guys thanks.
AE86Drift is offline
post #2 of 3 (permalink) Old 04-05-2010, 06:11 PM
gagamba's Avatar
Date registered: Jun 2007
Vehicle: 2000 SLK230
Same problem I have. My SLK was park for winter, I started the car no problem. after a while SE comes on (P1420). Clean the MAF, drove for 80 kilometers the following day no SE. I thought my problem was solved, today SE is back with a combination of P0170 and P1420. My car is a 2000 SLK 230.
Please help!
gagamba is offline
post #3 of 3 (permalink) Old 04-07-2010, 05:43 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 91 Post(s)
A search for "P1420" on the R170 forum came up with these threads:
Benzworld.org - Mercedes-Benz Discussion Forum - Search Results
I will let you look through them! Hope you figure out the problem. If you post you question in the forum specific to your model, in this case R170, you are more likely to have someone who can help you. The search button in the upper right helps too.
Mike
Michael Pillay is offline
SLK 230 Engine Oil Light Came On. Does this mean impending engine failure? miurasv R170 SLK-Class 13 03-30-2010 09:22 PM
1998 SLK 230, check engine light.... karrnut R170 SLK-Class 2 11-23-2009 05:09 AM
2000 slk 230 check engine light amihuicho R170 SLK-Class 1 08-20-2009 04:51 PM
Code the Engine Start of SLK 230 fsical R170 SLK-Class 3 08-13-2007 08:18 PM
SLK 230 1999 stock radio code EJ dans22 R170 SLK-Class 6 11-09-2004 01:18 PM
