P0446 code - Charcoal canister shut-off valve - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-23-2010, 08:15 PM Thread Starter
Date registered: May 2009
Hello All,
my wifes 02 ML320 is showing an 0446 code. If I clear it using my scanner the code will reappear right away (2 starts cycles). Performance of the car does not seem to be affected in any way. I have replaced the actual canister shut-off valve itself with no change, and had the vehicle smoke tested which proved there where no system leaks. However it appears that neither the shut-off valve nor the purge valve under the hood seems to be engaging. Both are getting 14-volts on their power wires when measured to chassis ground, and do engage if "chassis" ground is applied to the low side. However I only measure ~10volts between the power wire and its own ground signal wire. Not enough to trigger them I'm guessing. I understand that the ground wire carries the control signal from another module (N3/10???) which I am not sure where is located.
Soooooo, long story short, I hoping for any clues or direction to help solve this mystery. Am I overlooking something obvious? Where might I find this N3/10 module? Other likely culprits? Thanks to all.
skymaster is offline
post #2 of 3 (permalink) Old 05-25-2010, 11:46 AM
Date registered: Apr 2010
Vehicle: 2001 E320 sedan
New charcoal canister shut-off valve not closing.
2001 E320 appears to have these same symptoms. Installed a new charcoal canister shut-off valve which is not closing. Voltage measured at the valve measures the expected +12v when system calls for the valve to close. Bench testing proves the valve is working. The line current appears to be too low to close the valve. Any ideas? Expecting a dirty connection but unsure as to were to look for the problem.
This is my first posting and looking forward to hearing from those with experience. Thank you for the support, Dennis
Bohmer is offline
post #3 of 3 (permalink) Old 05-27-2010, 08:16 AM Thread Starter
Hi Bohmer,
After several hours in the local MB shop we did finally trace down the problem. It seems that both the Charcoal filter valve and the purge valve (located under the hood) have 12v applied all of the time and the main controller switches the ground to open and close them. In my case the wiring harness had chaffed in a small spot where it runs through the left rear wheel well in into the body. This allowed moisture into the ground wire and caused it to corrode and fail. Because I was using chassis ground when taking my measurements I didn't catch this. So the fix was to replace about 6 inches of the wire to remove the bad section just where it enters the body of the car. 4 hours of labor for a few cents of wire. Frustrating but it's fixed and working as it should now.
Hope this helps
    DIY Charcoal Canister & Valve CambridgeMA W210 E-Class 7 08-09-2011 01:13 PM
    gas leak from charcoal canister shutoff valve dabek10 General Mercedes-Benz 7 03-28-2009 01:51 PM
    Code P0455 & Charcoal Canister & Valve WhiteGrace W202 C-Class 2 09-22-2008 08:55 PM
    Charcoal canister shut-off valve? Dan Tomlinson R129 SL-Class 2 03-29-2008 02:04 PM
    1997 S420 Charcoal canister and valve location aljabari W140 S-Class 0 09-14-2007 06:39 PM
