94 C280 Key problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-22-2010, 04:22 PM Thread Starter
Date registered: Mar 2010
94 C280 Key problem
hi i bought a used c280 as my first car
the problem i have is they key use to start the car wont open the doors
next the way i could get into the car was what appears to be an aftermarket keyless remote fob which ran out of batteries
i replaced the batteries but it still does not open the locks of the car
can anyone help?
simi510 is offline
post #2 of 4 (permalink) Old 03-22-2010, 05:47 PM Thread Starter
i think ill try getting a new key but im not sure im locked out of my car
simi510 is offline
post #3 of 4 (permalink) Old 03-22-2010, 10:31 PM
Diesel Benz's Avatar
Quoted: 39 Post(s)
Sounds like the ignition barrel has been swapped to a used one from another car and door locks have not been changed. You should have had original keys for the doors when you bought the car. At least you can get the correct key to your door locks from the dealer if the door locks are original.
Do you have any manual for the after market remote? Perhaps it would explain if it has a rolling code and needs to be initialised after a battery change (meaning you should get into the car first to get it working).
Diesel Benz is offline
post #4 of 4 (permalink) Old 03-23-2010, 09:42 AM Thread Starter
yeah i ordered a new key i bought the car used so i dont know if i can get manual to get the rolling code thanks for the help though
simi510 is offline
'86 190e Ignition key problem- the key won't turn Guest (MBNZ) W201 190-Class 7 04-13-2010 03:35 PM
does my car have a chip key 1994 C280 snowskateskate W202 C-Class 11 04-13-2010 03:11 PM
Key problem - Expert level problem analysis required philthompson W123 E,CE,D,CD,TD,TE Class 2 09-26-2006 07:48 AM
95' C280 Ignition key won't turn Hollisterguy00 W202 C36 AMG, C43 AMG 2 06-24-2005 01:08 PM
95' C280 Ignition Key Won't Turn Hollisterguy00 W202 C-Class 0 12-22-2004 07:18 PM
