Greetings, 1st Merc and loving it! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-21-2010, 07:56 AM Thread Starter
Date registered: Mar 2010
Vehicle: 1991 420 SEL
Hello all Benz lovers. This seems a fantastic resource, I am also a member of Jag Lovers and I have such an appreciation for these sorts of sites, they offer a fantastic resource for enthusiasts who like to work on their own cars but need opinions and advice from those who have already done it.
I recently bought my first Mercedes, She's a 1991 420SEL in what I would call Teal with 143K miles. At first I was put off by the problems I encountered while test driving but it all turned out well. NO rust, perfect paint except the rear bumper which has a couple superficial nicks, Florida car (really) with a bit of service history (I cannot find a timing chain R&R), all original paperwork and even the window sticker.
The power steering pump was gurgling, Radiator was leaking, the brakes (DID NOT) work, the wiper motor was shot and there were 18" AMG rims on the car. Antenna went within a week so bought a new mast, ripped it apart and cleaned it up.
Owner replaced Radiator for me and I requested new hoses as well.
I topped up the steering fluid, problem solved and doesn't leak at all.
Bled the brakes because the owner showed me reciepts for replacing the Master cylinder and Booster, no more issues.
Bought a wiper motor on eBay for $40.
I also got some refurbished OEM wheels with good rubber and new lug studs by trading in the AMG rims.
There are a couple things to sort such as removing the remote start because it really doesn't work all the time, the squeeking alternator, refilling the AC because it hisses (Has already been converted to 134A), cruise, Pads...rotors...flex lines, Trans service (shifting hard when cold), Center console Zebrano is not looking too hot, Timing guides and chain, Might as well replace water pump and fill system with MB coolant, Fix cold start lumping, Ignition Wires...cap...rotor (already replaced Plugs with W8DC Bosch non-resistor), and whatever catches my fancy when I am stuck in.
Could someone tell me if I got a good deal for 3K? Any opinions what I should do to keep the old girl purring on all 8 reliably.
ID:	297536   Click image for larger version
ID:	297537   Click image for larger version
91420SEL LVR is offline
post #2 of 3 (permalink) Old 03-21-2010, 11:20 AM
F1Bobby's Avatar
Date registered: Sep 2008
Vehicle: C55 AMG
F1Bobby is offline
post #3 of 3 (permalink) Old 03-22-2010, 11:58 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
    New User and 1st MB owner. Loving life! rhy General Mercedes-Benz 1 12-25-2009 12:47 PM
    MY 1st MERC: Why you need a W123? benzmizer W123 E,CE,D,CD,TD,TE Class 14 05-11-2009 10:21 AM
    260e from Japan - 1st time in a benz, and loving it ! - TAKE 47 andylite W124 E,CE,D,TD Class 0 03-30-2006 02:35 AM
    260e from Japan - 1st time in a benz, and loving it ! andylite W124 E,CE,D,TD Class 0 03-29-2006 09:44 PM
    Just bought my 1st Merc 1stW124 W124 E,CE,D,TD Class 1 02-22-2005 03:27 PM
